cable tv connector - Event Date: 05 Feb 2015 |
ReiMan1776
Newbie Joined: 25 Jun 2014 Location: Encinitas CA Online Status: Offline Posts: 31 |
Calendar Event: cable tv connector Posted: 09 Feb 2015 at 1:55pm |
My cover broke off when I picked it up from the dealer brand new, flimsy plastic. Taking back to the dealer for multiple issues including this one.
Dan
Podster
Posted: 06 Feb 2015 at 9:41pm |
Ok, it may just have a couple of screws in the face of the plate, if so, after removing them it should pull right out...you may have to work at it some if there is some sort of sealant between the plug plate and the wall of the POD. The most critical part of this DIY job is to make sure, when you re-install the plate that you seal the plate to the wall so rain doesn't penetrate the wall by getting behind. Good luck!
Cliff & Raelynn
geelse
Groupie Joined: 10 Jan 2013 Location: California Online Status: Offline Posts: 65 |
Posted: 06 Feb 2015 at 9:12pm |
I'll let you know how my DIY turns out. Thanks.
See America First
2013 R-POD 177 HRE 2005 Dodge Dakota Quad Cab George and Linda |
geelse
Posted: 06 Feb 2015 at 9:08pm |
THANKS PARTNER,
Talked to local shop and got info on replacement steps. Will try DIY. PS: The Mrs. is rolling her eyes!
See America First
Podster
Posted: 05 Feb 2015 at 7:14pm |
Dang, broken cover...shoot! Well, my POD is in storage so I can't inspect it, but is should be pretty straight forward.
Any chance you can post a pic? Is there any way to replace just the cover without getting into replacing the entire plate? I think the key here is understanding how it is attached to the wall of the POD. It could be held on by wing tabs or it could be pressed into sealant or both. The challenging part of this job is getting it off there. Once you have it removed all you should find on the inside is the 1 or 2 cable (RG6) connection(s) screwed to the back. So at that point its just probably a 7/16 wrench to disconnect then then reconnect to the new place. Does anybody out there know how the outside service plates are attached to the POD? Anyway I would say once you understand how they are affixed, this is certainly a DYI project. There is no power or critical components to contend with. The connections there are simply an access and feed-point to connect services that run via cable up to the HDTV plate inside the POD. Good luck, come on back and let us know how it turns out!
Cliff & Raelynn
Posted: 05 Feb 2015 at 7:08pm |
Should be very easy. The wiring behind will unscrew from the terminals.
geelse
Posted: 05 Feb 2015 at 4:15pm |
Rpod 177 - 2013.
Outside cable connector fixture, cover broke off, temp fix has been tape. Is replacing whole fixture an easy job or do I call in the pros? I do not use the satellite connector so no problem there. Thanks.
See America First
