Wall anchors? |
ausdland
Newbie Joined: 24 Jan 2015 Location: SF Bay, CA Online Status: Offline Posts: 29 |
Topic: Wall anchors? Posted: 05 Mar 2015 at 9:24pm |
Thanks, I'll have a look but we want to mount that handle on the outside wall closer to the toilet. Maybe sheet metal screws will hold if it's just sheet aluminum; if not, I guess it'll be molys. |
2002 Toyota Tundra
2015 R Pod 178 Next adventure? |
Buxmont
Newbie Joined: 25 Sep 2014 Location: PA Online Status: Offline Posts: 9 |
Posted: 05 Mar 2015 at 11:42am |
As far as mounting the handle in the bathroom, if its opposite from the toilet you can remove the access panel on the bed side to see where studs are as well as looking in the wall from under the sink. I've done both (looking where studs are, and are not) for a tv mount on the bed side, and a reassessed (between studs) marine toilet paper holder.
2015 178 Rpod
2003 Chevy Trailblazer |
ausdland
Posted: 05 Mar 2015 at 12:21am |
Thank you
2002 Toyota Tundra
M0tl3y
Groupie Joined: 21 Sep 2014 Location: Utah Online Status: Offline Posts: 61 |
Posted: 04 Mar 2015 at 9:04pm |
I use the extra short hollow wall anchors
http://www.lowes.com/pd_326640-10457-7304_0__?productId=3415974&Ntt=short+hollow+wall&pl=1¤tURL=%3FNtt%3Dshort%2Bhollow%2Bwall&facetInfo= |
The 178 club
Podster
Posted: 04 Mar 2015 at 6:58pm |
This may provide some insight, but you will still probably have to probe for the framing.
Cliff & Raelynn
Outbound
Posted: 04 Mar 2015 at 5:35pm |
There are wood studs on the interior bathroom walls. But, of course, if you use molly bolts, you don't need studs.
But, you might want to consider if 3M Command hooks will do the job. Also, Scotch Mounting Tape works very well for 2-3 lb items (and can be cleanly removed afterwards, with a little patience).
ausdland
Posted: 04 Mar 2015 at 12:10pm |
Thanks. Do you know if there's a wood stud in the bathroom? My stud finder is useless in the pod. |
2002 Toyota Tundra
Posted: 04 Mar 2015 at 10:32am |
Several of us have used Molly bolts for bigger stuff. I used 1 1/4". The only handle I added I mounted directly to a wood stud.
ausdland
Posted: 04 Mar 2015 at 12:23am |
I want to install a couple hooks and a shelf in the kitchen/slide out of our 178 and a grab handle in the bathroom. Is there wood in any of the walls? What are people using for wall anchors?
2002 Toyota Tundra
