  New Posts New Posts RSS Feed: towing vehicle
Topic Closedtowing vehicle - Event Date: 16 Jul 2015
JohnBG View Drop Down
Direct Link To This Post Calendar Event: towing vehicle
    Posted: 16 Jul 2015 at 4:19pm
I'd read the owner's manual and see what it says.  WARNING - There may be some math equations involved.
For example with my Honda Ridgeline, according to the manual, the more people or cargo I have in the TV, the less weight it will tow.
Weight is weight, and there is no getting around that.  But if you put the items in the behind the center of gravity of the trailer instead of the TV, that might lighten up the tongue load and less stress on the TV suspension.
Crack that owner's manual out of the glovebox and RTFM.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
ontheroadagain2 View Drop Down
Direct Link To This Post Posted: 16 Jul 2015 at 3:47pm
Sleepy I have a 2013 Toyota 4Runner, it's tow limit is supposed to be around 4,700# to 5,000# based on all the tow charts, questions to mfr., etc.
I've been told that towing 500# more in the trailer is the same as loading the 500# in the TV.  Essentially, that there is no difference in where the weight goes.  It will affect the towing limit because either way it is affecting the TV's performance and causing it to work harder.
Is this correct? Thanks
Steve with a 172 Pod
'04 Americamp M 270RKS 5er @ seasonal site
