Unclewillis
Topic: dry ice in he fridge Posted: 13 Aug 2015 at 10:46am |
wow, great responses. Thanks all!
Daddy, Mommy and Daughter.
Rpod 176T 2015
Nick:
ouR-pod
CFWARREN
Posted: 12 Aug 2015 at 10:28pm |
I think dry ice works best when packed in a small container, on top of food being kept cold or frozen. I doubt that dry ice in a fridge or freezer would change the temp inside very much...in other words, it can be used to keep things frozen that are already frozen, but it won't cool down the space, if you get what I mean.
2016 179 - Hood River Edition
2008 Nissan Xterra
CFWARREN
Posted: 12 Aug 2015 at 10:26pm |
Dioxide...thanks, I get those two mixed up. The original question was about using a little dry ice, and there's probably no harm in doing that. A couple of years ago, I tried using dry ice, as an experiment, in a cooler. I found that it cost way more than regular ice, and melted away much quicker. At least with regular ice melting in a cooler, it makes for some nice cool water for the dog's water bowl....!
2008 Nissan Xterra
NMJohn
Posted: 12 Aug 2015 at 10:21pm |
Yes, it's carbon dioxide, the same thing we breath out all day. I think a better approach would be to put it in a small cooler with the food while the refrigerator cools down.
CFWARREN
Posted: 12 Aug 2015 at 10:18pm |
I wouldn't...dry ice gives off carbon monoxide, or is it carbon dioxide....? Either, way, you probably don't want to be breathing it. Also, the usual disclaimer for using dry ice in a cooler or ice chest is to leave the lid open a crack, because it causes the air to expand. If you had dry ice in your fridge with the door securely closed, it could cause it to explode, wrecking the door or seal. I wouldn't take a chance.
2008 Nissan Xterra
Podster
Posted: 12 Aug 2015 at 9:54pm |
Dumb? No, necessary...eh. I have not heard of folks using dry ice, but I have read about Podders that will use a couple of those freezer blocks to help it along.
Cliff & Raelynn
Ranger 4.0/178
Unclewillis
Posted: 12 Aug 2015 at 9:51pm |
Is a small bit of dry ice in the fridge a good idea to get the compartment cool quickly while the normal fridge operation is starting up?
For instance, pulling your Rpod out of storage on a hot day and needing cooling sooner than later.
Is this a dumb idea?
Thanks in advance
Rpod 176T 2015
Nick:
ouR-pod
