water pump |
Post Reply | Page 12> |
Tars Tarkas
Topic: water pump Posted: 29 Aug 2015 at 4:18pm |
You can fill the HWH with city water or from the potable tank. Either way, open the hot water valve at the sink a little bit at let the air come out until it stops spitting and there is nothing but water coming out of the tap. If you're filling from the potable tank you might want to top it off. Then you're you're set to turn on the gas or electric element.
TT |
FJ Cruiser |
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4514 |
Posted: 29 Aug 2015 at 3:07pm |
Just connect it to city water. We then run some water through the lines and go out an hit the switch turning on the hot water heater.
GLBCamper
Senior Member Joined: 30 Jun 2015 Location: Oregon Online Status: Offline Posts: 274 |
Posted: 29 Aug 2015 at 2:27pm |
Bumping my question up.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab New: 2016 EVO ATS 200rd 2016 F150 4x4 Sport |
GLBCamper
Posted: 26 Aug 2015 at 11:06pm |
Thanks so much!
Old: 2014 177 HRE
SNO4ME
Senior Member Joined: 28 Sep 2013 Location: NW Wis Online Status: Offline Posts: 122 |
Posted: 26 Aug 2015 at 9:50pm |
You need to bleed the air out of the water heater. Open your hot water faucet let it run till it stops sputtering and a little extra just to be sure. This is especially important if you use the electric heater. If the heating element is not fully immersed in water it will burn out in very short order. Another reason to do fill you water heater at home. If you do this on the road and you are dry camping you may be using up valuable gray water capacity. (IF that is a concern) |
Bruce & Donna in the Sno Pod
(and Brewer too) 2011 RP 177 |
wingnut2312
Senior Member Joined: 25 Aug 2013 Location: MI Online Status: Offline Posts: 231 |
Posted: 26 Aug 2015 at 9:33pm |
Thanks all! Figured it was the empty tank, but thought I'd ask anyways.
2014 rpod 182G
Ford Expedition |
GLBCamper
Posted: 26 Aug 2015 at 8:18pm |
Is the hot water heater filled simple by connecting to city water, or do I need to do something else? How can I tell if it's full before turning it on, so I don't burn it out?
Old: 2014 177 HRE
Posted: 26 Aug 2015 at 7:04pm |
+1 to everything said above. Leave the water in your system between trips. When you are boondocking you will then have 6 more gallons of fresh water available. In the spring when you do your first fill, hook your hose up to the city water connection and fill your water heater before you leave.
john in idaho
Posted: 26 Aug 2015 at 4:00pm |
If you don't mind carrying water, fill the tanks at home. Get everything working right in the driveway then shut it off for the trip. should work again.
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1219 |
Posted: 26 Aug 2015 at 1:23pm |
You also need to have the hot water tank full of water before the heating element is turned on or the element will burn out.
