Beveled or steel-belted tires |
Topic: Beveled or steel-belted tires Posted: 20 Jan 2016 at 8:32pm |
Radials are good for a softer ride. Bias have a stiffer sidewall which helps to prevent sway.
headcold
Senior Member Joined: 13 Nov 2013 Online Status: Offline Posts: 125 |
Posted: 20 Jan 2016 at 7:13pm |
Thanks, folks. radials they will be.
Posted: 20 Jan 2016 at 6:08pm |
On an '11, I would change the tires before the next season. They are 5-7 years old now. No matter how good they look, they are at the end of their service life. The factory tires on '11s are from '10, or earlier. We had one owner at least who had one come undone this summer in the FB group, who found the tires on their '11 were from '09. There is a 4 digit code on them, in an oval, that denotes month/year of build..
Posted: 20 Jan 2016 at 4:53pm |
The factory tires on our 177 have 20,000 plus miles and still look really good. They have worn and traveled well, when the day comes to replace, I will probably go with steel belted again unless I hear otherwise to go with plan "B"
Posted: 20 Jan 2016 at 3:31pm |
AS far as "preferred"..I can only state that the factory puts radials on every pod built. Tire discussions often deteriorate into fist fights, so I am leery of getting into them.
john in idaho
Posted: 20 Jan 2016 at 2:47pm |
It is probably the Spell-Check. My computer can come up with the doggonedest replacement words.
headcold
Posted: 20 Jan 2016 at 2:14pm |
Darn .... correction. My question should be: What is the preferred tire for the Pod: BIAS-PLY or radial. I guess I experienced a little memory gas in the short-recall department. I don't know where I picked out the term "beveled". So, I will float this question out again.
Capt Kidd
podders Helping podders - pHp Joined: 18 Aug 2015 Location: Chico, CA Online Status: Offline Posts: 212 |
Posted: 20 Jan 2016 at 11:10am |
What are beveled tires? Never heard of them.
Posted: 20 Jan 2016 at 9:33am |
Never heard of anyone using beveled tires anywhere but show or race.. I personally have no issue with steel belted radials on a trailer.
headcold
Posted: 19 Jan 2016 at 10:06pm |
O.K., here's a topic that will elicit wildly differing opinions .... at least that what my research is discovering; but I need to hear your experiences as applied to R-Pod in particular.
I need to replace the old Mudstar knobby tires on my 2010 177. Should I purchase ST steel-belted or ST beveled tires as replacements? My Pod hibernates at least 4 months in our Montana winters, covered Pod, covered tires but that is a factor. Opinions? Suggestions? |
