  New Posts New Posts RSS Feed: Exterior Lighting - Solar/Security
Topic ClosedExterior Lighting - Solar/Security
Don Halas View Drop Down
Direct Link To This Post Topic: Exterior Lighting - Solar/Security
    Posted: 19 Mar 2016 at 7:05pm
That will have to happen when it's in the field.
Direct Link To This Post Posted: 19 Mar 2016 at 7:26am
Good point
GLBCamper View Drop Down
Direct Link To This Post Posted: 19 Mar 2016 at 1:50am
Have you tested the "trigger radius"? I would hate to have this go off every time someone drives around the campground.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 18 Mar 2016 at 9:05am
This thing is bright.   I mounted it over the door using two modified suction cups (modified meaning I remove the hooks and replaced with appropriately sized screws).
It's been holding tight on the pod for a week now with rain and some pretty good wind.
I think this will work really well, and we'll be able to easily remove it when the dome is up and leave on a table or the trailer hitch during the day to get sun if we want to.
CozyPod View Drop Down
Direct Link To This Post Posted: 28 Feb 2016 at 7:10pm
Good idea Don! Might have to add this to my next Amazon order. I think the weight is light enough that suction cups or hooks from Command Products should work.
David & Suzanne
Direct Link To This Post Posted: 28 Feb 2016 at 9:56am
I'm considering purchasing the following solar/motion sensing light.
http://www.amazon.com/dp/B016I3GUYM/ref=psdc_14107631_t2_B016A5C5QA
My intent is to mount over the door with velcro or suction cups (it weighs about 3/4 lb.) and to take off the trailer when mobile.
I'm wondering if anyone has any experience with this or has done something similar.  I'm concerned with the mounting , I don't want to use screws or drill exterior holes.  Also, the brightness of the unit when activated.  Might it become a nuisance to camping neighbors?  Also I'm sure it will be of no value when the dome is up.
I thought it might be most useful for security, especially if boondocking in a parking lot somewhere.
