  New Posts New Posts RSS Feed: Floor repairs
Topic ClosedFloor repairs
StrongPod View Drop Down
Direct Link To This Post Topic: Floor repairs
    Posted: 25 Jul 2016 at 5:05pm
What did  you add to your floor to remove the soft/spongy feeling in the hall section?
I have heard of people laying laminate flooring? Do the floor supports on the Rpod run East and West (from door to cabinet?) as opposed to North and South (from the dinette to bed or hitch to rear)?
2010 RPod171 w/ V8 F150
kymooses View Drop Down
Direct Link To This Post Posted: 06 Mar 2016 at 10:59am
Yup some Pod models just have open spaces underneath where there is no support for the floor, some of those can get more flexy after a while.
Had spots like that in my 181g.  There's a big section of several feet where there is no support underneath.
Just needed something added to make that support, floor was fine after.
Direct Link To This Post Posted: 05 Mar 2016 at 8:48am
Some pods have demonstrated a soft spot there just due to flex. The floor is a sandwich of luan and foam, in a aluminum frame. FR has put an extra stiffener under that area if no leak was found.
CharlieM View Drop Down
Direct Link To This Post Posted: 04 Mar 2016 at 6:07pm
Soft floors indicate rot caused by a water leak. Could be from a plumbing leak or a rain leak.  You have to find and correct the leak first, then repair the floor. This usually involves removing and replacing the rotten section. Not an easy or fun job.
cburlette View Drop Down
Direct Link To This Post Posted: 04 Mar 2016 at 4:32pm
i have a 2010 Rpod 175 and the floor just outside of the bathroom is soft and flexes considerably. Has anyone experienced this and if so is the repair expensive?
Thanks
Craig Burlette
