Tow capacity - Event Date: 23 Mar 2016 |
Post Reply | Page 12> |
Tars Tarkas
Calendar Event: Tow capacity Posted: 24 Mar 2016 at 8:34pm |
We usually carry a few gallons as others have noted. In my experience with dry camping most campgrounds have water and a dump station somewhere within fairly easy distance of the campsites. There are exceptions, of course, and all kinds of camping places.
We were on the road for 3 or 4 nights straight a few months ago, and stayed at Walmarts along the way. I had to get enough water on board for a shower at one point. It's usually not too difficult to find. Others have said, and I pretty much agree, that no one ever complains about having too much towing capacity. In my opinion a TV with a 3500lb towing capacity may be enough, but it sure isn't too much. If or when you have a chance to upgrade to another TV you should probably look for at least 5000lbs. A lot depends on how long your trips are and the general terrain though. TT |
FJ Cruiser |
Mountainrev
Senior Member Joined: 22 Jul 2014 Location: Eagle, Colorado Online Status: Offline Posts: 193 |
Posted: 24 Mar 2016 at 7:27pm |
Regarding traveling with the fresh water tank full or not, keep in mind that a full tank not only adds weight, but depending on where the tank is located, could adversely affect tongue weight, and therefore handling. On my 177, the freshwater tank is cleverly located behind the axle, meaning that filling it takes weight off the tongue. The lighter the tongue, the more sway you'll experience. I'm not sure about 178s, but I wouldn't be surprised if they have the same tank layout as the 177.
If you are going to dry camp, and the campground is a ways away from home, I'd recommend filling the tank somewhere close to the campground, if possible. If there's a rest stop or city/county park not too far from the campground, and it has a threaded faucet that you can access, you can possibly fill up your Pod with your white hose. Another option is to use a jerry can to fill, but that takes several trips and a lot of effort. |
2014 177
2008 Jeep Grand Cherokee Turbodiesel "I lift my eyes to the hills." |
Nanny Rocks
Newbie Joined: 22 Mar 2016 Location: Canada Online Status: Offline Posts: 3 |
Posted: 24 Mar 2016 at 6:11pm |
Thank you all. Hubby and I just want to travel and sightsee not just head to a camp so wondered about having needed water to do that. Our van manual says 3500 lbs. does that mean weight of van loaded or does it included weight of people etc in van? Looking forward to getting van just want to make sure we understand what it will take. So appreciate your advice.
Nanny Rocks
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3252 |
Posted: 24 Mar 2016 at 5:39pm |
Since we normally dry camp we always have a full tank when we leave, and as JohnBG stated above, add 250 lbs. to your towing weight. 30 gallons can last quite a long time depending on how miserly you are with it. When dry camping, you tend to be miserly.
JohnBG
Senior Member Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Posted: 24 Mar 2016 at 5:27pm |
8.34 pounds per gallon, If you fill the fresh tank with 30 gallons, that's 250 lbs. We camp primarily at places with water and electric hookups, so we only carry a few gallons of fresh water for hand washing and toilet flushing while traveling. Always keep a few gallons in the black tank so that things don't solidify in there.
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
Guests
Guest Group |
Posted: 24 Mar 2016 at 4:47pm |
Welcome to the group! Good luck in purchasing your Pod. Leo B would not tell you wrong. Check to see if you have the same engine as he. We get some lively debates going in regards to tow vehicles. Don't tell anyone but, I've been known to "fan the flames/stoke the fire" in a debate or two. |
Posted: 24 Mar 2016 at 1:08pm |
If you anticipate dry camping (no hookups), then you have no choice but to travel with water. Best to start is full water and empty black and gray water tanks if that is the case.
If you are anticipating going directly to a site with hookups, you can get by with minimal water in the tank (enough to operate the toilet if the sudden need arises while you are on the road and no rest area is nearby). |
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4517 |
Posted: 24 Mar 2016 at 8:57am |
We usually use KOA campground on our trips, an using Flying J/Pilot truck stops in between, so we usually carry 5 gallons while traveling. it doesn't seem to adversely effect our driving or mileage.The only true enemy of towing his WIND. We usually average 15.5-16.5 once out of Vermont. If we hit a strong head wind, it will drop to 12.5.
Nanny Rocks
Posted: 24 Mar 2016 at 12:36am |
Thank you. Do you travel with water as I heard it can weigh a lot.. As you can see we are newbies.
Nanny Rocks
Leo B
Posted: 23 Mar 2016 at 10:03pm |
Welcome to the group! We tow our 179 with our 2013 Grand Caravan with the Pentastar 3.6 engine. We have towed up and down the coast with out any problems, gets pretty good gas mileage.
