  New Posts New Posts RSS Feed: Furnace blows air but no heat
Topic ClosedFurnace blows air but no heat
Jenga Jack View Drop Down
Direct Link To This Post Topic: Furnace blows air but no heat
    Posted: 19 May 2016 at 12:21am
Good to know. Thank you both!
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Direct Link To This Post Posted: 19 May 2016 at 12:20am
Thanks for the info. I'll give it a try this weekend.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 18 May 2016 at 5:48pm
Exactly as CharlieM says above. Make sure your stove-top can light. This means you have propane and the valve is actually open. After the furnace ignites, it can take a minute to begin making hot air.
 If after all that it will not light, it means that there is probably an electrical fault at the igniter. There is a flame detector built in, and no flame after it tries to ignite means it shuts down. If you run out of propane while running the furnace, it will detect the flame out condition and stop running too.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
CharlieM View Drop Down
Direct Link To This Post Posted: 18 May 2016 at 3:31pm
Originally posted by Jenga Jack
My 2014 R-Pod 178 furnace/heater is under the bed. When I turn the thermostat to heat, the furnace clicks on and blows air, but the air never warms up/heats. When I adjust the thermostat temperature up or down, the air temperature doesn't change.Ouch
Suggestions?
Check that the propane is on. The furnace will not heat unless it is getting propane. Light the kitchen stove and let it burn for 30 seconds to get all the air out of the lines. The furnace fan will run for 20-30 seconds at first to clear excess propane from the burner, then it should light. You should hear the burner running and feel heat  shortly thereafter.
Direct Link To This Post Posted: 18 May 2016 at 3:20pm
Suggestions?
