Problem Hot Water With 110 - Event Date: 25 May 2016 |
Calendar Event: Problem Hot Water With 110 Posted: 27 May 2016 at 9:59pm |
Check out the checklist in the link in my signature.
koukla1812
Newbie Joined: 15 Jul 2013 Location: Quebec, CANADA Online Status: Offline Posts: 21 |
Posted: 27 May 2016 at 3:07pm |
Just to mention that the element replacement was a success and relatively easy to do. The Youtube videos are really helpful. Learned a lesson about dewinterization from all of this. Make sure the outside heater switch is off whenever water heater tank is empty!
PJ |
PJ
koukla1812
Posted: 26 May 2016 at 9:56am |
Thanks for your help. The Youtube videos are clear enough that I'll dare to try and change the element myself. Again, thanks very much for taking the time to respond.
Paul J. |
PJ
Don Halas
Senior Member Joined: 01 Jul 2015 Location: Connecticut Online Status: Offline Posts: 190 |
Posted: 25 May 2016 at 11:46am |
I had a similar situation. Hot water on AC takes considerably longer than the propane.
CharlieM
Posted: 25 May 2016 at 11:37am |
Check that the small rocker switch on the water heater itself is on and both black reset buttons are pushed. These are accessible from the outside if you open the WH access panel. If all these are OK and the circuit breakers are all on, it would point to a burned out element. Search youtube.com for Suburban SW6DE water heater. You will find several videos on how to test and replace the element.
koukla1812
Posted: 25 May 2016 at 11:27am |
Can't get hot water when electric switch is used. Everything works when gas is used. When electric only no, hot water. Here's what I've checked. Our 178 (past warranty) is connected to 110 at the house and everything else electric in the pod works. There isn't a fuse blown as far as I can see. The wh tank is full of water. I' ve filled with the pump and checked for this. My only guess is I might have blown the electric element when dewinterizing. Are there other things to check? If not, I guess I should try replacing the electric element. Can someone indicate where that is on the heater and is it an easy job for someone...learning as they go...to do? Thanks for any help you all may offer.
Paul Jones |
PJ
