200 W solar mod |
Post Reply | Page 12> |
Author | ||
JandL
Senior Member Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Topic: 200 W solar mod Posted: 30 May 2016 at 9:05pm |
I didn't now I could edit once I had posted, I just corrected the voltage. Thanks for the information
JandL
Posted: 30 May 2016 at 8:50pm | |
You should be able to edit your own post until someone else quotes it. I think that is the cutoff. I could edit it but I'll leave it so my post makes sense.
WillThrill
Senior Member Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
Posted: 30 May 2016 at 4:34pm | |
Well if solar panels are getting stolen off people's rooftops, then those on your RV haven't got a prayer. This makes an even stronger case for movable panels that can be moved into storage when you aren't present.
2014 Hood River 177 2005 GMC Envoy XL |
JandL
Posted: 30 May 2016 at 1:51pm | |
It's not the pawn shops, they are somewhat regulated, the problem is the online sites like Craig's List. There is a lot on Google about theft of solar panes from the roofs of homes.
JandL
WillThrill
Posted: 30 May 2016 at 12:13pm | |
That's true. However, until pawn shops are willing to accept solar panels, I doubt that there is a big risk of theft of solar panels. The reason that Honda and Yamaha generators get stolen so often is because any pawn shop will take them in a heartbeat. That being said, I don't typically leave my panel out when we're going to be away from the Pod for hours unless I really need the battery to be recharged.
JandL
Posted: 29 May 2016 at 9:55pm | |
I wish I could go back and edit the post it should have said 13.6-13.8 volts, the 18 was a typo
JandL
Posted: 29 May 2016 at 9:14pm | |
I hope you weren't hitting 18+ volts, at most a 12 volt system should see around 13.5 volts with a normal charge, and up to 15 volts during an equalization charge.
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 29 May 2016 at 6:52pm | |
True enough, but remember, volts X amps = watts. 1/2 amp at 18.8 volts is 9.4 watts, a tiny fraction of the output that a 100 watt panel should produce. The controller is what adjusts the current and voltage delivered to the battery. A one amp current is probably enough to keep fully charged batteries topped up. |
JandL
Posted: 29 May 2016 at 4:54pm | |
"That's why I'm not a big fan of mounted solar panels on an RV, at least for us."
I installed my panels with clamps so when need I can remove them and place them on the ground and point them toward the sun. The cable is about 12' long so I can move it to any side. The big advantage of clamping them to the roof is I hope they are a little harder to keep from walking away |
JandL
WillThrill
Posted: 29 May 2016 at 4:31pm | |
That's why I'm not a big fan of mounted solar panels on an RV, at least for us. We typically use our Pod in the summer, and we have a big preference for shaded campsites, but this does not work well at all with solar panels. I put my single 100 watt Renogy panel on a 15 ft. cord so I can move it around to the brightest spot.
