Page 12> |
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
![]() Posted: 07 Jun 2016 at 12:40pm |
Make sure to post a review in the Dealer Reviews section.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6298 |
That is unfortunate. It is sad that you now know more than the dealer's service department.
ron/roscoe ![]() Groupie ![]() ![]() Joined: 13 May 2016 Location: Hanahan, SC Online Status: Offline Posts: 84 |
Dealer was a joke! They did not show me these things because they had no clue on how to find them.
Sell/sell is all that matters. The service Dept had nice not knowing people in their shop. Twice I had it in for service, same BS each time. All was ok each time. 200 mile round trip. Worthless shop.
Ron Rowland
Your dealer did not help in that he did not show you these things. Forest River is trying to squeeze a lot into these R-Pods. They did provide access, even if it is inconvenient. Your dealer should have shown you how to access things like the hot water heater valves and the winterization connections for the water pump. More detailed documentation from Forest River wouldn't have hurt either.
Thanks, FR does not make this easy.
Ron Rowland
Shelpod ![]() Groupie ![]() Joined: 14 Sep 2015 Location: Arizona Online Status: Offline Posts: 74 |
The valves on the 178 can be reached in two ways. Inside the outside storage at the back on the road side there is an access panel that can be unscrewed. If you are small you can crawl up in there enough to see the valves or you can reach in there and by feel set them correctly. The other method is to lift the bed and unscrew the plywood and lift that at the back. That is hard work but you can see what you are doing. Many people either create an access panel under the bed or just leave the plywood unscrewed for future access such as while winterizing. I have long arms so I reach in through the storage area. Neither way is great.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package |
ipoder ![]() Newbie ![]() Joined: 19 May 2016 Online Status: Offline Posts: 13 |
The valves are under the bed
lift the ply wood
I'm still looks for the valves for the he HW heater. I looked under the bed on my r178, there is a single sheet of 4 x 8 plywood, I did not remove it. I looked outside in the heater compartant, no luck. I did crawl under the frig with the slide in and found the piping for the heater but no valves. This is getting me plenty upset. Once I get the slide out again, I will go under the slide and look for the valves. Btw, can you move the slide without power? Somebody out there must know where they are located on a R178.
Ron Rowland
The valves will be located right next to the water heater. Locate the WH by looking on the outside for a grill about a foot square with a single small latching device near the top. The WH is inside the Pod, directly behind that grill. The valves will be right next to that. It may be under the bed or benches and require removing a plywood panel under the bed or seat.
Thanks for the help on my HW heater problem. I went to locate the valves today, I looked under the entire length. I went inside and liked under the sink and the area behind a false wall under the sink .
Where are the three valves located. I will fix this issue when i find the valves. There is another panel under the sink, I did not look there. More help is needed . Thanks, Ron
Ron Rowland
Page 12> |
