  New Posts New Posts RSS Feed: Plastic molding between sides and roof
Topic ClosedPlastic molding between sides and roof
Direct Link To This Post Topic: Plastic molding between sides and roof
    Posted: 15 Aug 2016 at 9:59pm
Someone else would need to verify the width.
mjh203 View Drop Down
Direct Link To This Post Posted: 14 Aug 2016 at 8:48pm
I appreciate the link.  Do you happen to know for sure if I need the 1" size?  My R-Pod is sitting in storage about 30 minutes away...hoping to avoid a trip out to measure.
Thanks a bunch!
Direct Link To This Post Posted: 14 Aug 2016 at 8:16pm
Insert trim.  Cheap to buy, very easy to install.  Remove one screw on each end and it will peel out.
Rodpod View Drop Down
Direct Link To This Post Posted: 14 Aug 2016 at 10:49am
I just had a length of the thin flexible plastic in the molding replaced by the dealer. I had damaged it a bit on the front curve by bumping into a building... long story.
The dealer called it 'screw cap' and charged me 45 cents / foot, plus labour. Seemed pretty reasonable.
2016 R-Pod 179
Direct Link To This Post Posted: 14 Aug 2016 at 8:41am
It sounds like we are talking about the same thing.
ragadas View Drop Down
Direct Link To This Post Posted: 14 Aug 2016 at 8:17am
I noticed that the thin plastic "cover" that runs in the top rail is cracked on my RP179 also if that is what you are looking at. It looks like it would be easy to replace.   I believe it's there to hide the screws that hold that rail on.
Dave & Chris
RP 179
2011 Tacoma Access Cab
V6 6 speed manual.
Direct Link To This Post Posted: 14 Aug 2016 at 8:11am
Hello,
I have found that the black plastic molding that runs along the edges of the roof line where it meets the sides of the pod have been damaged and are cracked (probably by hail) in many places. Does anyone know if this is difficult to remove and replace? Not sure if new molding snaps in, slides in,...? Also, any ideas where to buy it other than through the dealers?
Thanks!
