  New Posts New Posts RSS Feed: 179 Door Issue
Topic Closed179 Door Issue
MDPaddlersPod View Drop Down
Direct Link To This Post Topic: 179 Door Issue
    Posted: 24 Aug 2016 at 11:11pm
Thanks, I will get with the dealer.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
bjk View Drop Down
Direct Link To This Post Posted: 24 Aug 2016 at 10:57pm
You should be able to take it back to the dealer under warranty repair.
When I got my 179, the door latched normally, but it wasn't until my first trip did I discover that the deadbolt wouldn't lock (jamb/lock were misaligned).   I had to lock the door from the outside and then close the door (and make sure I had a spare set of keys in the truck for when I locked myself out). Smile
I was able to take it back and have this corrected by the dealer under warranty.
2016 HRE R-179 "CapPODccino"
2011 F-150 SLX
Direct Link To This Post Posted: 24 Aug 2016 at 5:55pm
JHoffman, the latch plates are not adjustable. I already looked at that, like adjusting a strike plate on a home door. The plate is screwed into the door frame without slots to adjust. I may have to make slots in the strike plate with a dremel tool.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
JHoffman View Drop Down
Direct Link To This Post Posted: 24 Aug 2016 at 5:46pm
I had to adjust the latch plates for both my main door and the screen door, it sounds like yours are set a little too tight, loosen the screws and move the latch plates outboard a little bit at a time until the door latches easily but still makes a good seal.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L
Direct Link To This Post Posted: 24 Aug 2016 at 5:09pm
I have to slam the door to get the catches to engage, does anyone else have this issue?
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
