  New Posts New Posts RSS Feed: How to connect a second battery
Topic ClosedHow to connect a second battery
sailor323 View Drop Down
Direct Link To This Post Topic: How to connect a second battery
    Posted: 13 Sep 2016 at 11:56am
If you want to add a battery, choose one that is the same size as your present battery.  Hook them in parallel, + to + and - to -.  Use 6 ga wire.  If you want to change over to 2 6 v golf cart batteries, hook one battery's pos to the other battery's neg and then hook the pod's pos cable to the open pos of one of the 6 v batteries and the pod's neg to the open neg of the other battery.  By connecting the pos of one battery to the negative of the other, you have created a 12v battery.
Direct Link To This Post Posted: 12 Sep 2016 at 3:20pm
You need to wire them in parallel..this is our old dual 12v setup.. you can see the positives and negatives are connected, then connected to the pod. The pod wires can be on the same battery, or one on each as required, some believe that putting the cables one on each battery is "better".. after talking to several EE's, the consensus is that in a 2 battery, 12v, bank, no measurable difference will be found. Mine ran in that configuration for 5 years, both batteries tested 100% and exactly the same capacity of charge, when replaced with dual 6's.
TheBum View Drop Down
Direct Link To This Post Posted: 12 Sep 2016 at 2:54pm
Your biggest gain for run time is to go to two 6V golf cart batteries in series. However, you can gain some run time by running two 12V batteries in parallel. All you need to do is get a second Group 24 battery and connect + to + and - to -, leaving the wiring into the trailer where it is. As for wire size, I'd recommend 8AWG or larger.
happywifehappylife View Drop Down
Direct Link To This Post Posted: 12 Sep 2016 at 1:19pm
I want to add second battery to my 2017 Rpod 179. What type and size of cables does it require? Can I do it myself, or should I take it to an RV dealer's service department? I have one new Group 24 battery that came with the trailer, and I want to add a similar battery to extend the time for dry camping.
