Water Pump or Check Valve Issue? |
Topic: Water Pump or Check Valve Issue? Posted: 17 Oct 2016 at 9:46pm |
Thanks Bill, I will check that out this weekend. If I find anything, I will let you know.
MoPod
Senior Member Joined: 10 Oct 2013 Location: Pittsville, MO Online Status: Offline Posts: 106 |
Posted: 16 Oct 2016 at 10:17pm |
Jato, our pump was running much more often, every 30 to 60 seconds at the end. But even at the beginning it was running about once an hour. But to answer your question: Our pod has a Shurflo model 4008. The check valve is on the end that the water hoses come in and out of. We replaced ours with part #94-800-03 (https://www.amazon.com/SHURFLO-94-800-03-Model-Check-Valve/dp/B00XKZ31VC) Before we replaced it we did the trouble shooting suggested by the manufacturer. 1) Is their sufficient water in the fresh water tank for the pump to pull up? 2) Do you have any leaks? 3) Is the strainer/filter clogged with debris? The strainer/filter is on the same end as the hoses and is a clear bowl that is just hand tightened. We removed this and soaked it in vinegar to ensure the was no crud in it. 4) Check for debris in the pump inlet/outlet valves.
BTW, we did remove our from the floor, but worked on it right there so we did not have to cut the crimps on any wires.
Good Luck! |
Bill & Nancy
2015 RPod 179 Previously 2010 RPod 176 2014 Explorer Sport |
Posted: 16 Oct 2016 at 9:00pm |
Bill, where is that check valve located? Once in a while ours does the same thing but maybe twice/day. Maybe starting to go bad but this is something we have heard for the past 2 years. Last week we were in the pod all day (for 1 day only) as we camped along Lake Superior and didn't feel like hiking or picking agates in 44 degree weather with 25 mph winds blowing off the lake with heavy rain, guess we felt like wimps that day. During the day we heard it do that 2 times, not at all during the night, were boondocking, so not hooked up to water or electric.
Posted: 16 Oct 2016 at 3:39pm |
Glad you got it diagnosed and fixed.
MoPod
Posted: 16 Oct 2016 at 1:52pm |
Ordered replacement check valve from West Marine. Installed, didn't really even need to remove water pump, but already had pulled it. Flushed all the lines one more time. Everything is happy!
Bill & Nancy
MoPod
Posted: 07 Oct 2016 at 5:58pm |
Attempted solution:
Disconnected city water. Put water in tank. Turned on water pump, ran faucets, water pump built up pressure, kicked off, 31 seconds later (not 29, not 33) water pump kicks back on. Left faucets closed, water pump continued to cycle on every 31 seconds. Turned water pump off. Repeated same process 5 times. Water pump continues to cycle on every 31 seconds. Connected city water again hear water running into fresh water tank.
I have verified the valve that would be used to suck up pink antifreeze is in the proper position.
Bill & Nancy
MoPod
Posted: 07 Oct 2016 at 5:04pm |
I apologize for bringing this topic up again, but the search feature is failing me or I'm using the wrong query.
Issue: 2015 179 - Water pump continues to kick on intermittently after pressurizing system (been doing for several months). Not running water pump when hooked up to city water. - Today (first time noticed) when hooked up to city water can hear sound of running water under bed near where water inlets and fresh water tank is located. - Previously empty fresh water tank has water draining when I pull plug. - No water leaks inside or outside the unit detected. - Previously had clog in cold water line going to kitchen sink - resolved. - Currently kitchen sink, toilet, indoor shower and outdoor shower have good water flow on both city water or water pump. My memory from reading about this before in this forum is a have a defective check valve. My memory doesn't remember what the solution is. If a new water pump required should I replace with the same as original or is there better, quieter, units out there for a similar cost. Thanks. |
Bill & Nancy
