  New Posts New Posts RSS Feed: Spark when connecting to home outlet
Topic ClosedSpark when connecting to home outlet
CharlieM View Drop Down
Direct Link To This Post Topic: Spark when connecting to home outlet
    Posted: 15 Dec 2016 at 2:22pm
Originally posted by TheBum
The house is brick veneer, so attempting to run wiring to the front of the house and out would also be a major chore.
How about across in the attic crawl space to a front corner, down the outside corner in conduit where the vertical will not be noticed, paint the conduit a matching color. Where there's a will there's a way. Approve
TheBum View Drop Down
Direct Link To This Post Posted: 15 Dec 2016 at 2:04pm
I wish I could run a 30A receptacle where it could reach our 179 when parked at home. Our driveway adjoins a common alley and there are many backyard fences to deal with, so maneuvering it into the driveway would be a major chore. As a result, we always leave it parked at the street curb when it's not in its offsite storage unit. The house is brick veneer, so attempting to run wiring to the front of the house and out would also be a major chore.
ChetC View Drop Down
Direct Link To This Post Posted: 14 Dec 2016 at 9:56pm
Most circuit breakers should never be used as a "switch" as they are not designed for switch service.  Constantly flipping the breaker will cause it to weaken and fail prematurely.
 If you desire to use it as such it should be, or be replaced with, a circuit breaker labeled "SWD" or "HID" as these are rated to handle switching service.
Former 2017 rPod 180 owner
Now in a 2019 Little Guy MAX
Full timer who logs more than 35,000 miles per year.
mcarter View Drop Down
Direct Link To This Post Posted: 14 Dec 2016 at 8:38pm
I learned from my military days in the 70s, hook power up with everything off and then apply power. To me it is as simple as you don't turn your blender on in the kitchen, then plug it in. It will spark. I do it by process, I do have the campground CB off until I'm ready to start the power up process, no sparks to date.
dr2428 View Drop Down
Direct Link To This Post Posted: 14 Dec 2016 at 7:41pm
Wouldn't hurt a thing to shut off the main (30A) breaker in the pod when plugging in/unplugging. Then turn it back on once connection is made.
That really just transfers the spark to the breaker. I suspect the plug would tolerate more connections and disconnections than a breaker will. Breakers are not designed to be switched often.
Do you not shut off the breaker at the pedestal every time you hook up at a campsite?
I do shut off the breaker at the pedestal every time I hook up at a campsite, my issue is at home where I don't have convenient access to the breaker serving my garage outlet. Doesn't look like much of an issue given the posts here? I may just suffer the trip to and from the panel to be safe. I'll be putting in a 30A connection outside my garage this spring which will have a breaker like in the campgrounds.
Looks like the question sparked a good discussion, this is what I appreciate most about this forum. I always get a lot out of this forum, best forum I've been on for any topic, campers, smokers, computers, etc.
Thanks everybody.
2017 RPod 179
2018 Chevy Colorado Z71 4x4
Direct Link To This Post Posted: 14 Dec 2016 at 2:49pm
Originally posted by GLBCamper
I noticed the same thing when I plugged into 110v with dogbone adapter and my Progressive Industries surge protector, so I contacted Progressive to ask them and they told me to ALWAYS flip the breaker at the house panel when making electrical connections or it could void my surge protector warranty if I don't.
I detect the BS flag waving...............and/or a well paid lawyer.
GLBCamper View Drop Down
Direct Link To This Post Posted: 14 Dec 2016 at 2:23pm
Luckily, the outlet I use is right next to my breaker panel, but I'd say it's worth the time even if it's a distance.
FYI, I have since installed a 30amp outlet next to my breaker panel and it was well worth the $40 in parts. It's a pretty easy job, just google for YouTube diy videos. It's easier because now it's on a dedicated breaker and I'm not shutting off other things in my garage every time I flip the switch.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 14 Dec 2016 at 1:51pm
I don't do that but I do turn off the WH to save the timed relay contacts in my SurgeGuard.
Direct Link To This Post Posted: 14 Dec 2016 at 1:46pm
Direct Link To This Post Posted: 14 Dec 2016 at 1:39pm
