towing |
Post Reply | Page 12> |
Tars Tarkas
Topic: towing Posted: 04 Mar 2017 at 9:55pm |
There might be a clue there. A dealer installed chrome plated ball might not be the best quality. Not much doubt in my mind that some dealers could find a ball that would look nice for 15 minutes and maybe last long enough to get you a hundred miles away. I've mostly gone with the most expensive stainless steel ball I could find. A good ball will, at least in my limited experience, last a lifetime. You can overpay and still spend way less than 50ยข a year on a good ball. But, yeah, you might have had some rough spots or grit or something on the hitch, which could cause wear too. TT |
FJ Cruiser |
Posted: 04 Mar 2017 at 8:45pm |
I also use the Sway Bracket Jackets on the L-brackets to quiet things down. The L brackets can be greased, but the Sway Bracket Jackets are much cleaner.
I don't know if it is normal, but the hitch ball that the dealer installed does show wear. The shiny chrome coating is worn off and a brass color is showing in those places. This started the very first time we towed. I don't know if it means that the R-Pod's hitch has rough places that should not be there, but the wear is why I started greasing the ball. |
Tars Tarkas
Posted: 04 Mar 2017 at 8:36pm |
I just re-read your original post and it's clearer than I thought. Sorry. Any time two surfaces move against each other there is friction of course, but in the context of friction sway bars, the pivot points don't seem to me to be friction surfaces. Of course, if there wasn't friction, they wouldn't need grease. Too much said about this bit of trivia. I wouldn't have said anything in the first place if I'd read your post more carefully. TT |
FJ Cruiser |
Posted: 04 Mar 2017 at 8:17pm |
It is at the pivot points on the hitch head, not at the bar ends that hook on to the A frame.In the manual, page 23, Step 10 - Regular Maintenance:
"The friction surfaces of the head and sockets should be kept clean and well lubricated with a good quality multi-purpose or bearing grease. These are the surfaces where the arm sockets rub against the top and bottom plates of the head. . . . They should be lubricated before each trip. Check for damage or abnormal wear at the beginning of each towing day and replace if necessary. Clean dirt and road grit from all friction surfaces regularly." |
Tars Tarkas
Posted: 04 Mar 2017 at 7:41pm |
cjscint: I agree with Stephen. It seems most likely that the locking plate was in the way of the hitch coming all the way down on the ball. His method of getting in on is exactly what I do too. He and I have the same WDH too. You must have something different because there is almost no way in the world I could hook up my pod and the WDH and not have the ball locked on securely.
You might need some oil up underneath the hitching mechanism on the trailer. Sometimes there's a hole or two on the hitch you can squirt oil into, and I think there are places on both sides of the hitch that should be oiled. Having your hitch lubricated so that it can move like it should can help a whole lot. As for grease, I never used it until I got a WDH a few months ago. Roughly 50 years with no grease; 5 months with grease. I can't tell the difference, other than getting greasy every time I hook up now, but that's what the WDH instructions call for, so okay. It makes sense, but I never did it before. Also, for what it's worth, I've never seen any noticeable wear on a hitch ball. Stephen, your comment about greasing the friction surfaces is confusing. As I read them, the instructions call for grease where the sway bars are inserted into the hitch, right below/behind the ball. I wouldn't call those friction surfaces. To me, the friction surfaces are where the rear ends of bars rest on the things that hang down from the tongue. Those don't get grease, I don't think. If that's where you're talking about I need to go back and re-read the instructions. I also vehemently agree that if you don't think you're hooked up right you shouldn't get out on the road. Jostling things an inch or two on a level service to try to make it work, yes, maybe, but, as you say too, obviously not safe or acceptable to go down the road. I've done it inadvertently and amazingly, or by the Grace of God, only bent a jack. TT |
FJ Cruiser |
Oharley
Newbie Joined: 09 May 2016 Location: Kentucky Online Status: Offline Posts: 14 |
Posted: 04 Mar 2017 at 5:35pm |
The same thing happened to me when we first got our new 179. I found there were some burrs on the part of the collar that clamps the ball. I removed them with a Dremel rotary tool being careful to only remove what was needed to smooth out the collar. Now it clamps and releases as it should.
RP 179
2016 Ram 1500 5.7L Hemi 4x4 |
Posted: 04 Mar 2017 at 11:32am |
Grease: Equal-i-zer states to use grease on the friction surfaces at the pivot points of the bars. As for the ball, after the first time I towed and saw how much wear was there after that first time, I started using Reese Hitch Ball Lube. Using it and cleaning up after towing is likely cheaper than replacing the hitch ball and the trailer's hitch.
As for connecting, I suspect that when you lowered the hitch onto the ball, it landed with the locking plate sitting on top of the ball. If that is the case, it won't be able to lock. However, I don't know since I was not there to see what was happening. Other things to consider: Does the locking mechanism work freely when the trailer is sitting unhitched? Was the latch fully open? When I lower mine on, I try to aim it so that the ball hits toward the front of the trailer's hitch socket. I usually have to bump the TV forward just a bit until the ball is sitting against the front before I can lock it down. Then I use the jack to lift up to make sure it is securely latched. I need to raise it anyway to get the bars on to the brackets on the trailer's A frame. I hope you get it figured out. Towing with the trailer not hitched properly is not a good move. |
cjscinta
Groupie Joined: 21 Nov 2016 Location: Franklin, TN Online Status: Offline Posts: 84 |
Posted: 04 Mar 2017 at 10:00am |
Newbie here. Grease vs no grease. The dealer told me not to use grease. Negligible benefit and gets everywhere. What is your experience? Also,when I was hooking up the other day I got the coupler to drop down on the ball but could not for the life of me lock it down. Raised it up and down, moved the truck back and forth to no avail. What do you think the problem was? My driveway is not level so I towed it to a flat spot and still couldn't get it. I hooked up the weight distribution and pulled it anyway cause I only had a short distance but obviously not a safe or acceptable option. Any ideas? It worked when I picked it up.
2017 R-pod 179
Posted: 04 Mar 2017 at 8:16am |
Put on disposable gloves. Take paper towels along when unhitching to wipe grease off ball and WDH pivot points. Slide cover on ball. Remove gloves when done. Voila! no trailer grease on clothing.
Blue Highways
podders Helping podders - pHp Joined: 20 Sep 2016 Location: NC mountains Online Status: Offline Posts: 84 |
Posted: 04 Mar 2017 at 7:56am |
Excellent thread you started, MB2....
plus all the good comments that followed... I've been contemplating that another factor of good towing experiences is connected to one's developed skill in predictive driving. (which I'm sure we all have). Now weather and traction? That can be a different thing. Common scenario: you're moving along smoothly in the stream of traffic, burning your 13.5 m.p.g's of fuel. A big rig rumbles by, mixed with two amped-up drivers sort of playing horsepower tag with each other. (We've all seen it.) Everyone ahead is cresting the next hill in a collective clump; banked curve afterwards to the right. Just as they all drop over, 3 out of 5 vehicles still in view flash their brake lights. Response: off on the throttle a touch, finish the move to the right lane (before bypassing the debris of a centerline tire shred); ....open up space for the steadily-gaining 5th wheel to complete the pass. Grow the open space cushion. Eye the hazard button position. TANGLE UP: Damage here & there; one trailer with 2 bicycles softly (but sadly) laid over in the median grass, TV still upright....everyone's emerging from their various vehicles on foot OK. Lots of help around. Thankful for trailer brakes. Roll past the scene unscathed, behind the 5th wheel family. Later in the evening: (back at the campsite following grocery supply-run): "dang. Trailer ball grease got me again !...." <sorry, had to throw that in.) As my old friend Jim B. always says..... "Keep it safe out there...." ----------------------- 17 HRE 179 (WanderPod) BG (10 Tundra CM) B & L Nottingham Western NC |
