Another battery/charging sytstem question. |
Post Reply | Page 123> |
Author | ||
Topic: Another battery/charging sytstem question. Posted: 27 Jul 2017 at 11:45am |
Update: I ordered a replacement WF8955MBA converter from Amazon and had it delivered to a friend who was going to be coming to Vermont with the rest of the team. It was delivered to him, and he brought it with him. We received it and I installed it. It started operating as soon as I made the connections and turned my battery cut-off switch back on and then flipped the 120V breaker back on. It had some work to do as the batteries were somewhat low even though the panel lights still indicated "Good" for the level. The voltmeter told the real story.
Now that we are home, I have contacted WFCO and submitted the form to get an RGA number so this defective unit can be shipped back for evaluation and replacement. Once that is done, the defective unit should be replaced as it is still under warranty. That replacement will become a spare in case this happens again. |
Posted: 11 Jul 2017 at 8:07am | |
The charger I bought brought the battery up to 100%. We are dry camping now at Emerald Lake State Park in Vermont. If need be, I will hook up the generator's 12V connection and charge the battery that way since there is no 110V power here. We will see if we can go until Friday without needing to charge. Lights, vent fan, and my CPAP will be the main power draws unless it gets chilly and I want to run the heater to take the chill off. I don't think it will be cold enough to bring out the Mr. Heater Portable.
voisj
Posted: 10 Jul 2017 at 4:40pm | |
When my converter stopped working i just bought a small battery charger and plugged it in when i had shore power, Did this for three weeks, we were traveling every other day so my TV kept it charged the rest of the time. John
Posted: 10 Jul 2017 at 8:31am | |
The one I linked above... Inteli-Power 55 Amp Converter/Charger Model #PD4655V replaces these converter sections: Parallax/Magnatek #6355, Parallax #7355, Parallax #7155, Parallax #8355, WFCO™ #8955 On Amazon But deck mount isn't a big issue, I used a deck mount in furpod.. it mounted to the slide out tray, had to drill one hole, and I cut the back off the power center with a dremel, no big deal. |
Posted: 10 Jul 2017 at 7:18am | |
I had installed a volt meter. That is how I knew it was not working. I confirmed it when I turned my battery cut-off switch and everything cut off. No 12V power was being supplied. All the connections were tight. I have a WFCO 55A replacement on order. It will be delivered to our pastor and he will bring it with him when the rest of the mission trip team leaves home. We will meet him in Vermont and I will install it there.
The PD models I saw when I looked on Amazon were deck mount, not drop-in replacement to fit the WFCO panel. Is there one that fits in place of the WFCO converter? |
CharlieM
Posted: 09 Jul 2017 at 9:10pm | |
Agreed. If you have to replace the converter go Progressive Dynamics.
Posted: 09 Jul 2017 at 4:37pm | |
I did.. it was a better one because among other things, it was a four stage charger and conditioner. They are a couple hundred bucks. I used one I had bought for another project TT.
There is a pretty simple test of the charger converter, plugged in to shore power, just go in the 12v side of the panel and check voltage right there on the board, +13v means the converter is working. WFCO did have a run of bad converter/chargers, many 2015-16 owners have had to have a replacement, a few have needed a second.. and at least one owner I know of is on a 3RD.. If replacing on your dime, I highly suggest the 55A version of this.. Amazon is showing $216 today.. Best one out there IMHO.. |
Tars Tarkas
Posted: 09 Jul 2017 at 12:12pm | |
I've spent hundreds of dollars on batteries and starters in the past only to find out that a ground wire need to be taken off, wire brushed, and put back on. Expensive lessons, hard learned, although it almost happened to me again recently. My tractor wouldn't start. I'd checked the ends of about 7 wires and was pretty sure I needed a new solenoid. I was putting away my tools to go to the parts store when I realized there was one more terminal I needed to clean. The devil on my shoulder was telling me, "what are the odds? 1 out of 8... just go get the new solenoid." I listened to the angel on my other shoulder and Bingo!, that was it.
You need to check both ends of all wires. You're going to have to disconnect at least one end of them anyway to replace the converter/charger. Familiarize yourself with the job by doing a dry run, cleaning connections as you go. I don't know what it is, but there must be a way to check the converter/charger with a volt ohm meter at the unit itself. As far as testing for continuity, a corroded connection may let enough current through to indicate a closed circuit but not enough to do anything else. I think you'd need to check for proper voltage at the output of the unit. How much does a new converter/charger cost anyway? It seems like someone (Furpod?) said he'd replaced his with something better. Whoever that was, if you read this, what was it, why was it better, and what did it cost? TT |
FJ Cruiser |
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2654 |
Posted: 09 Jul 2017 at 10:53am | |
After all the work you had done, I am still inclined to believe that something came loose, or similar. If you have a DVM, I would check continuity between the converter output and the battery.
Posted: 09 Jul 2017 at 7:04am | |
It seems to have gone from intermittent to full failure. I bought a Schumacher SC4 15A charger / 3A maintainer from Walmart and have it connected. The charge state now is about 75% according to the charger.
