Rainy day electrical mods |
Post Reply | Page 12> |
CharlieM
Topic: Rainy day electrical mods Posted: 15 Apr 2017 at 11:31am |
A bit hard to tell without having the switch in hand, but I'll give it a shot until McCall comes in. The switch has 3 terminals because the LED indicator needs a ground. If you don't need or want the indicator you only need 2 terminals. Using your meter find 2 terminals that show continuity when "on" and no continuity when "off". Connect those 2 terminals, either way, in series with the positive terminal of the voltmeter. The third terminal on the switch is unused. The pictures on Amazon are a bit confusing because the automotive, boating and house wiring color coding conventions are different. |
john in idaho
Posted: 15 Apr 2017 at 10:57am |
The voltmeter and phone plug-in have spade connectors labeled plus and minus. The switch has 3 connectors, and it looks like I can see a minus sign between the two silver ones. Can those be combined into one lead? My continuity meter won't help me - I guess the switch needs current to work.
McCall
Groupie Joined: 16 Mar 2017 Location: McCall, ID Online Status: Offline Posts: 49 |
Posted: 14 Apr 2017 at 6:22pm |
Behind the lower cabinet there is only about 1", be careful there.
Gary E
McCall, Idaho 2017 RP179 https://www.instagram.com/erttergary/ |
john in idaho
Posted: 14 Apr 2017 at 5:35pm |
Will do. I forgot I have some. there is quite a bit of space between the wall and the cupboard wall.
McCall
Posted: 14 Apr 2017 at 4:30pm |
I used Forstner drill bits.
Gary E
john in idaho
Posted: 14 Apr 2017 at 4:18pm |
What did you use to cut the holes? I got my gauges today from Amazon
Posted: 08 Apr 2017 at 9:38pm |
Very nicely done. I want to do this mod. What did you use to cover the hole where the switch used to be?
Wood River Pod
Senior Member Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
Posted: 08 Apr 2017 at 8:41pm |
McCall pod...get out of my head. Wood River pod here. Working on the same mods this Idaho rainy day. You got a little farther than I did today. I'm moving the bathroom switch to a double switch with the porch light switch. Also doing voltmeter with on/off switch. Putting a plate over the the old bathroom opening.
Thanks for the info. Jeff |
Posted: 08 Apr 2017 at 8:11pm |
Very Nice ! You may get calls from other podders to do some similar mods.
McCall
Posted: 08 Apr 2017 at 7:50pm |
I got the meter from Amazon…
I mounted the charger and 12v socket by the heater outlet under the bed. For those I ran a fused line from the battery box. For the meter on the wall I got the power off of the control panels red (+) & white (-) wire.
Gary E
