  New Posts New Posts RSS Feed: Running heater
Topic ClosedRunning heater
mcarter View Drop Down
Direct Link To This Post Topic: Running heater
    Posted: 13 Apr 2017 at 4:55pm
The heater will heat the inside of the Pod, not the underbelly, maybe some radiant but not while towing. Pods are great but have limitations. Lot of posts on 4 season capability or lack there of. I'm not taking my Pod into obvious bad conditions, expecting it to survive a blizzard, or long term freezing temps. Or even bad road conditions, over confidence is a killer.
TheBum View Drop Down
Direct Link To This Post Posted: 13 Apr 2017 at 2:35pm
The Pod should shake around enough to keep the water from freezing without the furnace, if that's your concern.
RichC View Drop Down
Direct Link To This Post Posted: 13 Apr 2017 at 2:10pm
Realizing that it is possible to over-think everything, I'll go ahead and ask my question.
If, while de-winterized,  you anticipate unexpected cold weather (cold snap, mountains, etc.) can you or should you run heater while towing?
2017 RP171
2018 Ford Explorer
