  New Posts New Posts RSS Feed: Jensen DVD and TV
Topic ClosedJensen DVD and TV
Danielw1 View Drop Down
Direct Link To This Post Topic: Jensen DVD and TV
    Posted: 10 May 2017 at 12:03am
Is that all it was? Loose cables?
mcarter View Drop Down
Direct Link To This Post Posted: 09 May 2017 at 12:12pm
Pesky details :)
Roaming Around View Drop Down
Direct Link To This Post Posted: 09 May 2017 at 8:25am
Thanks Mike! I read the manual online before I posted, but didn't read past initial set up! Now see that I need to make sure cables are properly connected in back. Duh! Embarrassed
Direct Link To This Post Posted: 09 May 2017 at 8:05am
Try this link:
http://idn.tweddle.com/media/bundle-assets/Jensen-%20Mobile%20Audio%20System-%20AWM968.pdf
Forest River does have manuals on line. You have to go to the Travel Trailer section, then to entertainment and electronics, you will see a manual print on the radis, that is little help. But off to the right, there is an Associated PDF that is the manual for the Jensen player.
Direct Link To This Post Posted: 09 May 2017 at 7:48am
Built-in DVD does not project on Jensen TV -- I have a 2015 HRE 178 Pod (which I love, BTW!!). TV works fine as a TV, sound is coming from DVD, but no picture for DVD. Please help. I note that a couple others have posted the same question but there are no answers :-(
I don't have a manual which probably wouldn't help much anyway! I have googled everything I can think of but can't find an answer.
Thanks very much to whomever is kind enough to post a reply!!Confused
