Searching Problem |
fwunder
Topic: Searching Problem Posted: 11 May 2017 at 7:39am |
A workaround: Use Google. I think it actually works better anyway.
In your Google search box: rdome site:http://www.rpod-owners.com/ You can use the search tools to adjust time and sort. fred
Bugout
Senior Member Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Posted: 11 May 2017 at 6:58am |
+1
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Posted: 10 May 2017 at 5:52pm |
Something weird, about two weeks ago I would do a search and would indicate responses, then not display anything. I waited a couple days and it worked well, I thought. Now it's again indicating responses but no displayed results. It's not dependable.
Posted: 10 May 2017 at 5:20pm |
It used to work quite well. I'm not sure when the problem started. Hopefully, it will be fixed soon.
Happy Tripping
Posted: 10 May 2017 at 5:18pm |
The search feature, to put it charitably, has 'limitations'(!!!).
I just did an experiment, using the basic search, and put in 'rdome', got back 13 responses on 2 pages but the whole first page was blank, the second had 3 entries visible. If you have no success with the 'advanced search' either, give up until they cure the problem. Unfortunately, even when working well, the search function here is pathetic.
GLBCamper
Senior Member Joined: 30 Jun 2015 Location: Oregon Online Status: Offline Posts: 274 |
Posted: 10 May 2017 at 5:06pm |
Same here. It might say X number of results, but the page is blank.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab New: 2016 EVO ATS 200rd 2016 F150 4x4 Sport |
Elenaron
Newbie Joined: 14 Aug 2015 Location: Broward, FL Online Status: Offline Posts: 9 |
Posted: 10 May 2017 at 4:57pm |
When I do a search using key words, it says I get a number of posts. But nothing shows up (only a blank screen). Am I doing something wrong?
2014 R-Pod 178
2014 Ford F-150 |
