  New Posts New Posts RSS Feed: Water Leak RP 179
Topic ClosedWater Leak RP 179
MDPaddlersPod View Drop Down
Direct Link To This Post Topic: Water Leak RP 179
    Posted: 07 Nov 2017 at 8:20am
We just came back from camping yesterday and discovered water on the floor outside the bathroom. I found the source (sort of. I stuck my hand in the access hole behind the sink in the bathroom and felt water leaking from the pipes/fittings above where I could reach. Does any one have any advise or experienced this before? I am still under the extended Forest River warranty (into year two). The Pod is a 2017 RP 179. Any help would be greatly appreciated.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Direct Link To This Post Posted: 07 Nov 2017 at 3:03pm
I would bring it back to the dealer and have them fix it asap!
Direct Link To This Post Posted: 07 Nov 2017 at 3:46pm
+1 to Leo - you have a warranty take advantage of it. I have a 178 and access to the shower wall is limited, mine came with backflush check valve in backwards and to fix I would have had to remove sink. I relocated the backflush. Had I had a warranty I would have used it.
Direct Link To This Post Posted: 08 Nov 2017 at 6:55am
Thanks guys, you are confirming what I thought...USE THE WARRANTY.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
