  New Posts New Posts RSS Feed: Where toJack 179 to change tire
Topic ClosedWhere toJack 179 to change tire
TheBum View Drop Down
Direct Link To This Post Topic: Where toJack 179 to change tire
    Posted: 07 Aug 2017 at 1:25pm
If you jack where the axle attaches to the frame, the axle won't bend. I assume the axle is capable of holding up that much weight without being crushed, which is the only way it could be damaged.
PracticalPodder View Drop Down
Direct Link To This Post Posted: 15 Dec 2017 at 10:38am
Hello,
With regards as to where to PLACE the jack on an Rpod, in my case a 2018 178, should the jack be placed only on the bracket in the attached picture?
Haven't quite figured out how to get the picture to appear (I might not be able to link to OneDrive). Copy and paste these links into your browser.
Sigh, these links may not work. Let me know.
https://1drv.ms/i/s!AoFQRUJHVZ-Rth8cYS-SKpw_6vrN
Here is SteveH's homemade jacking block
https://1drv.ms/i/s!AoFQRUJHVZ-RtiCIeE8jistTFQUv
Or in the forum
http://www.rpod-owners.com/forum_posts.asp?TID=7712&PID=82715&title=our-escapod-mods#82715
Direct Link To This Post Posted: 15 Dec 2017 at 2:04pm
That is the best spot that I could find. You should have received a PM with the specific link showing the jacking block I made to best jack up the pod without putting pressure on the axle tube.
Direct Link To This Post Posted: 15 Dec 2017 at 3:47pm
+1, right under the riser bracket.
HARLEYULTRA View Drop Down
Direct Link To This Post Posted: 15 Dec 2017 at 4:13pm
Hi from Bill. Both FR & Lippert tell you different things. You are right you jack under the bracket & put a jack stand between the jack & tire while you do service work & you can relieve pressure on the jack.
funks View Drop Down
Direct Link To This Post Posted: 15 Dec 2017 at 5:32pm
Your right, the levitationizers on Amazon are expensive but well worth it.LOL
geewizard View Drop Down
Direct Link To This Post Posted: 16 Dec 2017 at 1:40pm
ditto
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
