Wepod
Topic: 15' tires Posted: 07 Jan 2018 at 11:26am |
I know this has been talked about before but can you replace the stock 14" tires on a non HRE pod with the 15" tires that come on the Hood River Pods? What size tire is on the HRE and who makes a good D rated tire and rim?
mjlrpod
Posted: 07 Jan 2018 at 12:16pm |
You can put 15 inch tires on. Just make sure you have clearance from the fender. I know on mine 15 inch will fit easily. Who makes a good D rated tire, is open to debate. I have carlisle tires, 14 inch D rated 8 ply tires. I changed out the C rated tires immediately, I just didn't trust running tires at or near their max recommendation. Many say goodyear endurance, and others say you should get E rated tires. I can say I have about 2500 miles or more on my tires and i have no complaints. They are cheaper than the goodyear, but not cheap tires. It's a matter of preference.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 07 Jan 2018 at 12:49pm |
I also have Carlisle tires, D rated on my 14" wheels. I would check out etrailer, they have tire and wheel sets at reasonable prices and a good selection, you're not going to get a lot of lift going to 15" tire and wheel
Wepod
Posted: 08 Jan 2018 at 8:17am |
I know I am not going to get a lot of lift going from a 14" to a 15" but I need to replace the cheep tires that came on my trailer after 15,000 mi. I am looking into a lift kit now with my dealer to see if that is available. I know the new HRE pods have the lift welded on to the trailer frame so the bolt on lift may not be available any more.
Posted: 08 Jan 2018 at 8:51am |
I agree with a tire upgrade, the D rated are way to go, you can also contact FR directly and inquire about lifts. I don't know which axle you have, but etrailer has lifts for the Dexter Torqflex. Good luck.
Wepod
Posted: 08 Jan 2018 at 2:19pm |
Just got back from the dealer the lift kit is available and will cost me $ 385.00 installed. They did one on another pod last week and got about 3" of lift so I am going that route. Still need to find tires and rims so I will be internet surfing for those.
Posted: 08 Jan 2018 at 3:35pm |
Cool. Good news
Posted: 08 Jan 2018 at 6:32pm |
Originally posted by Wepod
I know I am not going to get a lot of lift going from a 14" to a 15" but I need to replace the cheep tires that came on my trailer after 15,000 mi. |
Why do you need to replace your tirres so soon? We put many more miles and lots more years on ours, replacing them this spring in a trailer new in 2011. Our tires looked fine but I was concerned with the years.
2011 R-Pod 177
2010 Ford F-150
Wepod
Posted: 09 Jan 2018 at 7:35am |
The tires are not worn out but I want the 15" for more clearance and less roll resistance. Also I want to get a D rated tire as I think the C rated tires don't have strong enough sidewalls for a fully loaded 179 Pod.
jglynn55
Posted: 19 Feb 2018 at 1:13pm |
I had a blowout on the factory C tires so bought the D tires for my trip to Florida from Nashville. Wow, what a difference. I think the increased tire pressure helped. The C was 50 and the D is 65. The trailer seemed lighter and more balanced and less drag on my TV.
