TV RECEPTION |
Post Reply | Page 12> |
Author | ||
Topic: TV RECEPTION Posted: 05 Feb 2018 at 7:08pm |
I just checked out the M3D Micro+. I'm impressed. I'm looking forward to finding out how well the antenna mod works.
TheBum
Posted: 05 Feb 2018 at 1:53pm | |
Yes, I have a cheap 3D printer (M3D Micro+). The end caps are of my own design and printed with my printer; I got the gearbox design from Thingiverse.com and had a friend print it (before I had my printer). I'm not 100% confident that the gears he printed will hold up; I may re-print them in a stronger material or, if worse comes to worst, order them printed by Shapeways. I have the end caps keyed so I can cut a slot in the PVC to prevent rotation within the cap. |
Alan
Posted: 05 Feb 2018 at 11:18am | |
I am definitely interested in seeing the results. Do you have your own 3D printer? Is the gearbox in your design also 3D printed? |
TheBum
Posted: 05 Feb 2018 at 10:56am | |
I'm working on a way to put a King Jack on our 179 and bring the rotation control and signal meter into the front of the wardrobe on our 179. It involves a couple of lengths of 1/2" PVC pipe as drive shafts with 3D-printed end caps and a 90-degree gearbox. I plan to have one shaft come down from the antenna and through a hole in the top of the wardrobe, where it will go into the gearbox. The second shaft will go from the gearbox to a panel I'll mount at the front of the wardrobe, where I'll mount the antenna's control unit. |
Alan
Posted: 03 Feb 2018 at 8:03pm | |
Since I run Linux, I have used tools such as OGMRip to extract DVDs to files that I can take with me and play on either a computer or tablet. That way, we can watch a movie if there is no power or reception and we don't need cellular or wifi service either. Most of the time though, we read if we don't have power or reception.
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2595 |
Posted: 03 Feb 2018 at 6:30pm | |
I guess we are minimalist. We took our TV out. I kept bumping my head on it and we rarely go where there is shore power available anyway. (Cancelled cable at home, too.) And, we cut back on gvw by at least 15#.
If there is Verizon service, we can watch movies or listen to music on our computer or phone. I got a bluetooth speaker for about $30 and it works pretty well. And if there's no cell service, well, then we just talk, read, and enjoy the quiet.
Posted: 03 Feb 2018 at 4:54pm | |
+1 - Excellent point.
Posted: 03 Feb 2018 at 4:51pm | |
The problem with the older 179s is that the location of the antenna is such that there is no access to the antenna base to rotate it if it is replaced unless it is also relocated, leaving one with a hole in the roof to patch.
I had thought of changing the antenna and modifying the wall to make an opening through which the base could be reached to rotate a King antenna, but we really don't watch enough to make it worthwhile. |
Posted: 03 Feb 2018 at 4:34pm | |
Major improvement, I agree. Personally I didn't by a RV to watch TV, though, many have as evidence of the big trailers no one comes outside.
henryv
Senior Member Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Posted: 03 Feb 2018 at 4:30pm | |
You mean newer than that batwing on my 2016? The King HD..? How much? Can I do it myself? How easy?
