rawest50
Topic: Electrical backup lights Posted: 08 Mar 2018 at 9:19am |
Thanks. I take our Pod in for service tomorrow so when I have it high enough I will crawl under and get a better look. I used a selfie stick and took pictures but could not separate any of the wires. It is problay there covered by all the other wires.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
marwayne
Posted: 07 Mar 2018 at 6:18pm |
rawest, you are right the wiring comes in on the drivers side. Now since I'm such a nice guy I crawled under the pod in the snow to take a pic just for you.
rawest50
Posted: 07 Mar 2018 at 4:01pm |
Drivers side at the front corner? That is where all my wires go from the frame to the trailer underside.
2017.5 RPod 179
2 Weiner dogs
DenisP
Posted: 07 Mar 2018 at 3:06pm |
I just completed wiring backup lights on my 2010 171. I found the yellow wire under the left front corner and made the connection. Works great. Thank you Marwayne.
T@b 400 with solar
Formerly 2010 171
2013 Tundra TRD
rawest50
Posted: 05 Mar 2018 at 4:57pm |
I am back. I used my iPhone to check for a yellow wire. I cannot get under the Pod because driveway slopes & front of Pod very low to make it level. I have a bunch of white wired and a couple not connected to anything. No yellow. I will try to post a picture.
2017.5 RPod 179
2 Weiner dogs
rawest50
Posted: 24 Jan 2018 at 9:48pm |
Thanks. I will check it out. May be back because my Electrical skills are plugging prongs in a socket.
2017.5 RPod 179
2 Weiner dogs
marwayne
Posted: 24 Jan 2018 at 9:12pm |
If you look under the pod on drivers side, where all the wiring is located there is a yellow wire that is blanked off that is for the backup light.
rawest50
Posted: 24 Jan 2018 at 8:44pm |
I have a light bar I want to put on the rear of the Pod. I have plenty of wiring to run the length from the TV to the rear of the Pod. I need the reverse lighting on the TV. Wiring diagram shows the center pin of the 7 pin as the reverse wiring. Can I splice into it and make it work? The light works off a 4 pin but my past experience is that does not handle the reverse lighting. My Jeep I wired into the taillight.
2017.5 RPod 179
2 Weiner dogs
