  New Posts New Posts RSS Feed: Hot water heater
Topic ClosedHot water heater
henryv View Drop Down
Direct Link To This Post Topic: Hot water heater
    Posted: 09 Mar 2018 at 10:52am
I just sanitized my camper. Ran some bleach through. Since I want to drain it for travelling, should I also drain the hot water heater or just leave water in it. also which way should the valves coming off the hot water heater be turned. Then when I want to use the hot water heater, what do I do?
riotkayak284 View Drop Down
Direct Link To This Post Posted: 09 Mar 2018 at 11:19am
Hope you really didn't run the Clorox through the HW Heater. Supposed to be bypassed when sanitizing.
Direct Link To This Post Posted: 09 Mar 2018 at 11:30am
I do not bypass my hot water tank when sanitizing. I do remove the anode and flush the tank before sanitizing. At the end of sanitizing I replace the anode. I do not turn the heater element on during the process. A lot of folks share opinion the tank has to be bypassed, to me it is a tank, the bleach mixture is diluted.
Direct Link To This Post Posted: 09 Mar 2018 at 11:37am
Henryv,
After sanitizing and flush you should drain the water heater, most common way is to remove the anode rod. I do a final rinse on mine then replace the anode rod. There is a number of YouTube videos on the process. Also many Interweb articles.
Direct Link To This Post Posted: 09 Mar 2018 at 1:30pm
The hot water heater needs to be bypassed when using RV antifreeze, both because you don't really need to fill the 6-gallon tank with antifreeze and because the antifreeze will corrode the anode rod very quickly. However, the HW tank should not be bypassed when sanitizing as it also needs to be sanitized to avoid any bacteria growth, both in it and in the lines leading to and from it. as stated above, flushing it to get the remnants of anode rod corrosion out is a good thing to do also.
Direct Link To This Post Posted: 09 Mar 2018 at 3:10pm
+1 and in case of leaks. If you are a antifreeze winterizer, you don't want 6 gals of it in the water heater. I air pressure winterize, so never bypass the water heater. BTW - city water is chlorinated. If you are using city water, chances are you are sanitizing each time you hook up.
Direct Link To This Post Posted: 09 Mar 2018 at 4:30pm
Good point Mike, never thought of the fact of chlorine continually sanitizing the tank IF you are on municipal water.  We have always used well water in our 177 and funny thing is I never sanitized my water lines or tanks (dealer did that for me when we picked it up March 2011) until furpod told me I ought to and that was at the ERU in Traverse City during the summer of 2016).  So maybe I should be a bit more proactive in that department OR start using municipal water once in awhile.
Direct Link To This Post Posted: 09 Mar 2018 at 5:02pm
My experience with well water comes from TX. The Sulphur smell was terrible:) I agree if you have good well water use it, and sanitize. If you are using city water you sanitize all the time, just like your house on city water.
Direct Link To This Post Posted: 09 Mar 2018 at 5:36pm
Not to be a PITA, but isn't more correctly a COLD water heater? After all, once it's hot, then it's just a hot water tank. Clown
Direct Link To This Post Posted: 09 Mar 2018 at 6:40pm
LOL
