  New Posts New Posts RSS Feed: Tow Vehicle (is it enough?)
Topic ClosedTow Vehicle (is it enough?)
Heyjohn56 View Drop Down
Direct Link To This Post Topic: Tow Vehicle (is it enough?)
    Posted: 13 Mar 2018 at 5:04pm
We're going to be towing our pod with a Jeep Grand Cherokee Laredo 3.6L V6. Wanted to know if anyone has experience towing with something like this. I've seen pics of Dodge Caravan as the TV so I think I'll be ok. We have a Caravan but it says it tows up to 3500 lbs and we didn't want to go right up to the limit. The jeep says it can tow 5000.
John & Nancy
2017 R-Pod 178
2019 Dodge Durango V6
(hope it's enough)
Direct Link To This Post Posted: 13 Mar 2018 at 5:09pm
You should be ok. You are about at the 80% mark and you are correct we do have members towing with Caravans and other vehicles rated at 3500. I would not advise that. We also have a number of folks towing with Grand Cherokees. Are you using a WDH?
henryv View Drop Down
Direct Link To This Post Posted: 13 Mar 2018 at 5:16pm
I have a similar tow vehicle (6 cyl Ford Explorer)I personally think it's a perfect match for my 171. I've added extension mirrors which help.
Direct Link To This Post Posted: 13 Mar 2018 at 5:18pm
We towed our 171 and our 179 with our Dodge Grand Caravan for several years up and down the east coast. Had plenty of power and got pretty good mpg. We recently upgraded to a F-150, but still have the Grand Caravan.
Chris 'n Lou View Drop Down
Direct Link To This Post Posted: 13 Mar 2018 at 7:05pm
We have a #180 which we tow w/ a 6 cyl Toyota 4-Runner.  It is OK for up to 5,000 lbs.  No problem - just don’t load yourself down w/ too much “stuff”.
2018 - #180
‘04 Toyota 4-Runner Ltd
jalong View Drop Down
Direct Link To This Post Posted: 14 Mar 2018 at 7:38am
I tow a 179 with a 2014 Grand Cherokee Laredo that has the towing package making the tow rating 6200lbs. I use an E2 sway weight distribution hitch. My Jeep has an economy shift mode that I turn off when pulling a trailer. Last year I replaced the OEM trailer tires with D range Goodyear Endurance that makes the towing even better.
John & Sue
2016 179 - built in April 2015
2014 Jeep Grand Cherokee 3.6L 13-16mpg with 179 - 21-28mpg without
Direct Link To This Post Posted: 14 Mar 2018 at 9:15am
Thanks all. I don't have a WDH. I asked the dealer about upgrading from just a sway controller, but they said I didn't need to. Looking into mirror extensions but it seems like they would fall off at speed. My Jeep is only rated at 5000 lbs (not sure why) but it seems it will do the job based on others experience. I'm not going to push the speed. Take my time, try to relax and enjoy. Thanks again for all the input. Great group.
John & Nancy
2017 R-Pod 178
(hope it's enough)
Direct Link To This Post Posted: 14 Mar 2018 at 9:28am
We had a set of mirror extenders that we had gotten at Walmart and we used them on our Grand Caravan
in 9+ years of towing with the van we never had one come off and we would hit 70-80 at different times . Though we mostly cruise at 55-60 most of the time.
Larry-D View Drop Down
Direct Link To This Post Posted: 14 Mar 2018 at 9:57am
With the width of the pod you may want to think about mirror extensions.  I tow with a Wrangler and found the extensions made no difference since the pod's width was less that a trailer with its wheels inside the body instead of outside.
I do use a WDH.  At the dealer I had them hook it to the Jeep w/o the WDH and it set pretty level.  Kept thinking about it overnight since we use a WDH on our truck and larger TT.  Decided that, for my peace of mind I wanted the WDH.  Is it necessary, I don't know but I do know that in pulling the pod back from FL which was our first pull with it, it handled great.  Took a good hit on gas mileage but pulled, straight, level and no sway with the sway bar.
TheBum View Drop Down
Direct Link To This Post Posted: 14 Mar 2018 at 11:43am
We tow our 179 with a 2012 3.5L V6 Highlander with tow package and it has handled mountains admirably. We use a Fastway E2 WDH. We bought a set of extension mirrors and only used them once; the side mirrors are fine if I lean sideways a bit.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
