  New Posts New Posts RSS Feed: Trailer Coupler Lock
Topic ClosedTrailer Coupler Lock
 Post Reply Post Reply Page  <1 4567>
Direct Link To This Post Topic: Trailer Coupler Lock
    Posted: 16 Mar 2018 at 11:23am
Originally posted by henryv
Don't get much for a nickel anymore! I thought of an idea too..I have a friend who's a welder. Spot weld a couple little pieces on the inside that would prevent the puck from moving so much.
So, since it was Friday, and the weather is nice.. I did some experimentation.
If I remove the outer collar, and mount the lock to it, I can wobble the lock quite a bit. But, that's because of free play with the narrower hasp point..
So, looking at it.. my $.05 fix. (it actually took $.10 to make this perfectly snug) in this setting. Again, for whatever reason, (manufacturing tolerance stacking I am sure) Ours is perfectly tight when assembled and mounted.
They could be held in place with a drop of super glue or silicone, heck, even duct tape..
Direct Link To This Post Posted: 16 Mar 2018 at 1:36pm
A penny or two or three might be cheaper!
Could also just put a slug from an electrical box in there too. Probably cheaper than a nickel.
Direct Link To This Post Posted: 16 Mar 2018 at 2:51pm
I suppose, if you wanted to splurge, some combination of penny, nickle dime would get the very best snugness.. but who knows how much $$$ you might be out in the end... Wink
henryv View Drop Down
Direct Link To This Post Posted: 16 Mar 2018 at 6:24pm
Ingenious! You guys are cheap!        I'll give it a try...
Direct Link To This Post Posted: 17 Mar 2018 at 10:34am
I found the perfect solution. I had a couple of small round magnets that stick to the steel. Also sprayed the lock with some Blaster silicone lubricant and it works smoother.
Direct Link To This Post Posted: 17 Mar 2018 at 10:41am
I often put several drops of anti-seize into the lock mechanism of locks that live outdoors. Better locks made of stainless might not need it, but if there are any steel components inside, it will keep them moving smoothly. One word of caution, anti-seize contains graphite, and it will turn everything it touches black (but you can wipe it off). The nice thing about graphite is that it will stick once the liquid carrier evaporates.
DaveB1701 View Drop Down
Direct Link To This Post Posted: 15 Aug 2021 at 12:14pm
2021 R-Pod 171
2017 Chevy Colorado Z71 V6
Just me & my pooch Mr. Buster...
Direct Link To This Post Posted: 16 Aug 2021 at 12:07pm
IMO, the best trailer tongue lock is the one made by Proven Industries.
Direct Link To This Post Posted: 16 Aug 2021 at 4:48pm
+1  Purchased ours 4 years ago.  Not cheap but I agree with GG - it is the best out there.
Colt View Drop Down
Direct Link To This Post Posted: 18 Aug 2021 at 6:52pm
Whats wrong with a Master lock through the hitch latch?
John
'16 R-Pod 180
