Bed Shelf |
Post Reply | Page <123> |
Topic: Bed Shelf Posted: 26 Apr 2018 at 3:54pm |
My shelf rests upon the valence and is anchored to the wall, supported by a full across wood closet rod. There is very little weight on the valences. I would guess I have 20-30 punds up there to answer the other question, clothes and medical stuff. Nothing heavy.
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 26 Apr 2018 at 5:47pm |
This makes sense, as long as you also anchor it to the wall. Didn't want folks thinking that resting it on the valance alone would be adequate.
Posted: 26 Apr 2018 at 5:51pm |
I had same thought, agree with you. I didn't go with wooden full shelf also because of weight.
Posted: 26 Apr 2018 at 5:59pm |
Was in Lowes today they have 3 of these shelves SH mentions, 75 bucks apiece. With hardware as SH mentions.
Posted: 26 Apr 2018 at 9:55pm |
The shelf itself is not that heavy. Metal shelving would be heavier I think. The wood used for them is very light but the shelf seems to be quite sturdy. Mine rests on the valences, but the command strips I have do support some of the weight as well. I don't load it down with heavy items. Other than my CPAP machine, the baskets we have on it hold my clothing as my wife uses the wardrobe drawers for hers. A lot of items either go in the wardrobe on th ecloset rod or on a separate rod that Iuse in the TV to carry any hanging items that won't fit in the wardrobe.
Ghosthawk
Senior Member Joined: 01 Apr 2018 Location: Fargo ND Online Status: Offline Posts: 128 |
Posted: 27 Apr 2018 at 7:07am |
Thought about attaching an L shaped piece of wood the length of the shelf with Command Strips.
Unsure how much load it would handle. I have expandable shower curtain rods in my Amazon Basket, should take more load properly installed and should do no damage. But it is a more costly option. If I could be sure I would hit the aluminum frame I would drill it and put in an anchor. But not sure I want to trust my wifes packing them full to just a few screws into fiberglass panel. |
Posted: 27 Apr 2018 at 9:23am |
The interior panel is not fiberglass, but is thin lauan plywood with a wallpaper cover. If you use an expanding anchor, (make sure it is less than 1" in length or you will experience outer wall puncture (ask me how I know ). Fortunately, when the R-Pod went to the factory for repair, they replaced that side so no more puncture evidence.
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 27 Apr 2018 at 9:27am |
Thanks everyone for your inputs on how you did this shelving mod, just keep them rolling in! At $75 for a wooden shelf it makes pause and think maybe wire might be the way to go, don't know? I'll have to take a hard look at the valances and how they attach if anyone has a photo of that they can post it would be appreciated. Again thanks for all the great suggestions!
Ben Herman
Posted: 27 Apr 2018 at 3:53pm |
I just removed my valances so don't have a photo of them installed - but basically they use metal angle brackets (the same ones that FR uses as drawer pullout limiters - if you look in the drawers you'll see what I mean). One side of the bracket is attached to the wall with 2 - 5/8" screws, and the other side with 2 - 5/8" screws to the inside of the valance. Not terribly sturdy. Hard to get to the screws to remove the valances, had to get on my back on the bed with a drill with a long Phillips extension.
Posted: 27 Apr 2018 at 4:17pm |
DavMar,
Looked at the wood shelf today at Lowes - 75 bucks, I also wanted the over bed light to be somewhat functional. I felt the wire shelf provided more light through to sleeping area. |
