  New Posts New Posts RSS Feed: Newbie questions
Topic ClosedNewbie questions
Tom A View Drop Down
Direct Link To This Post Topic: Newbie questions
    Posted: 06 May 2018 at 3:19pm
We had a successful one night maiden voyage to a local State Park about an hour from home.  So a few questions came up.
How thick are the interior bathroom walls?  I want to put up some towel hooks on the wall between the bath and the bedroom.
Is there a way to find stud locations on exterior walls?
The water heater did not come with instructions.  I did getting working on shore power, but I've no idea how to fire it up with the propane.
2018 Sequoia--2018 RP 190
mjlrpod View Drop Down
Direct Link To This Post Posted: 06 May 2018 at 3:47pm
Your exterior studs can be found rather easily this time of year. On cool mornings the dew will often show the layout of the studs at first sunlight. As far as the water heater, look at the control panel that has the water pump switch, and the tank monitor lights. There is a switch that says water heater. make sure your propane is on and ofcourse there is water in the tank. Its better if you can be outside and have the wife turn it on while you watch. (HINT) don't get to close when it's lighting or you'll get singed by the exhaust when it lights (whooosh). Once the switch is pressed, you should hear a clunky noise (gas valve opens) then a series of clicking sounds as the igniter produces sparks. If it doesnt light immediately, it will make 3 attempts to light it. The "dsi" light next to the swith will light up if the attempts fail. If all 3 attempts fail, it will stop trying to light, and the dsi light will stay on. At that point, let us know.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 06 May 2018 at 4:12pm
Tom A,
The interweb is the best source of info on how to use your water heater on propane., recommend you start compiling an info book and copy print the various systems and how they work and how to operate. I have a 3" binder of info I keep with Pod. You will need it as issues arise.
Pods don't have studs per say, they have aluminum framing, mostly around windows and door. You can use dew lines but hard to extrapolate from outside to inside. Best to buy a good stud finder that will locate metal and electrical. I have used a very small drill bit if in doubt, one I could easily hide any wall damage. Granted tee dew lines are very prevalent on outside walls.
Lastly - I wouldn't use anything over 1" on the walls - anywhere.
voisj View Drop Down
Direct Link To This Post Posted: 06 May 2018 at 4:55pm
Dew lines,
SLOPODMODS
John&Sue,SLO,CA
Ben Herman View Drop Down
Direct Link To This Post Posted: 06 May 2018 at 5:00pm
I use sheetrock wall anchors, the ones that look like this:
When using these in sheetrock, you just hammer them in to start them. However the Rpod wall is a thin plywood veneer over foam, so I predrill a small (like 1/4") hole before  carefully driving these in with a screwdriver. Suggest just using a hand screwdriver, not power - it'd be too easy to drive these in too deep. Also be careful not to drill the hole deeper than 1 inch. Others on the forum have previously mentioned drilling too deep, and going through the wall.
Direct Link To This Post Posted: 06 May 2018 at 5:51pm
Thanks, I have used those anchors successfully in sheetrock walls, that's a good idea.  But, are you talking about exterior walls?
I still don't know how thick the inner partition walls are (bathroom).
Direct Link To This Post Posted: 06 May 2018 at 5:54pm
yes, exterior walls. Not sure how thick the interior walls are (and cannot get out to TT right now) but should be fairly easy to tell by looking at the bathroom door area. Try a search on this forum, I would imagine something'll come up...
Direct Link To This Post Posted: 06 May 2018 at 5:56pm
As far as the water heater is concerned, I did use the On/Off switch on the bathroom wall.  When nothing happened I looked in the tank compartment and found another, unlabeled rocker switch down in the corner and flipped that-- got hot water right away and I assume that was from shore line electric power.
Thanks folks.
Direct Link To This Post Posted: 06 May 2018 at 6:29pm
You're correct on that switch in the water heater compartment. You just need to make sure there is water in the tank when you use the WH connected to shore power or it will blow the heater element inside the tank.
Direct Link To This Post Posted: 06 May 2018 at 7:05pm
Another newbie here with a follow-up question - do you have to flip the switch each time you go between shore and lp for the water heater? If so, I definitely want to move the switch. Getting under the bed each time seems like a real pain in the butt
