  New Posts New Posts RSS Feed: Wheel Bearing Service Questions
Topic ClosedWheel Bearing Service Questions
grizwalsh View Drop Down
Direct Link To This Post Topic: Wheel Bearing Service Questions
    Posted: 11 May 2018 at 12:33pm
How often--mileage wise--do you grease the bearings?
grizwalsh
Direct Link To This Post Posted: 11 May 2018 at 2:01pm
Originally posted by MDPaddlersPod
David, thanks. I appreciate the idea with the brake cleaner. I am going to do that. What and where is the zerk grease fitting I hear folks talking about and what is it's purpose. Again, many thanks.
The zerk fitting is on the tip of the spindle. If you are doing a repack, this can be avoided.
There has been much written about "EZ Lube" type axles - both here on the forum and elsewhere. Below is a link or two that I have written. Personally, I would go ahead and do the clean/inspect/repack this time. That way "you know what you got". The factories don't lube bearings like I do.....enough said. Next year/going forward, you can decide what you want to do.
http://www.rpod-owners.com/forum_posts.asp?TID=11386&PN=4&title=wheel-bearing-maintenance
http://www.rpod-owners.com/forum_posts.asp?TID=11386&PN=1&title=wheel-bearing-maintenance
http://www.rpod-owners.com/forum_posts.asp?TID=6823&KW=Dexter&PID=64869&title=ez-lube-axles#64869
Direct Link To This Post Posted: 11 May 2018 at 2:04pm
12mo/12000miles
Direct Link To This Post Posted: 11 May 2018 at 5:40pm
Thanks for the info
grizwalsh
