Page <1234> |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4512 |
![]() Posted: 22 May 2018 at 7:39pm |
+1 with Tars
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3237 |
We are still using the same anode rod that came on our 177 when we picked it up March 2011, so it is now over 7 years old, almost looks like new. Maybe because it has never seen municipal water with all the added chemicals, Our 177 has the FW tank in the rear, nevertheless we always leave with it full of delicious well waterl unless we are only going for a couple days, then 1/2 full is more than enough. Thanks to furpod we got on a semi - regular track for sanitizing our FW tank. Did it the first year we owned it and then went over 4 years before we did it again, Now we try to sanitize 1x/year just to be safe. Once we put water in our HW and FW tank which is usually late April or early May, it remains in the tank until we winterize in November. |
lgblau ![]() Senior Member ![]() Joined: 09 Feb 2018 Location: Arizona Online Status: Offline Posts: 140 |
Everyone, evidentially, missed the whole idea that I was relating to. It had nothing to do with the operation, and or maintanance of the water heater. I simply asked if anyone drained their tank to save on the weight. Sorry if I somehow confused my post. 😎
Leonard🌵
2017/179 2017 Ram 1500 |
Wind resistance is a much bigger factor than the approximately 50 lbs of water in the water heater. I agree that leaving it full is best. Quantity of water in the fresh water tank is a different question as to the amount to carry. We travel with a full FW tank since we do tend to stay at places without hookups while we are enroute to a destination.
Igblau,
Nope I don't drain water heater. Actually that 6 gals of water could come in handy. You can use the water pump and take water from hot side for emergency purposes. Won't be hot, but who cares. |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1446 |
We did go off on some tangents, but I think we mostly got your point and the answer is no, no one worries about that extra 50 pounds. It makes no discernible difference to your MPGs and if you are calculating your weight with regards to your towing limits that carefully, you should probably be looking for a larger TV. I was listening to Click and Clack, the Tappet Brothers, once when a listener asked whether driving with your headlights on (during the day) caused one's gas mileage to go down. His brother insisted it would. Of course the Magliozzis laughed and said no, but then they got into one of their "yeah, but" discussions. They allowed as how there is no such thing as a free lunch and yes, the extra electrical load on the alternator would cause the engine to use slightly more power (= gasoline). Short of some big fancy MIT white board calculations though, they guessed that 2 identical cars driving across country, one with lights on and the other off, assuming identical driving conditions, etc., the car without lights might use a dollar less in gas. 50 pounds of water would probably cost more than leaving your lights on, but still, it would take a pretty sharp pencil to calculate how much more. If your time is worth anything, you probably aren't going to come out ahead draining the water heater. And you could end up spending more on Teflon tape than you'll save on gas. TT |
FJ Cruiser |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
I'll add a little more to that. We have (had actually, sold it last year) a utility trailer that when full weighs as much or more than our R-pod. However, it is very low profile. The mileage we get pulling that utility trailer is at least 30% better than what we get pulling our R-pod. So the weight matters, but not nearly as much as the wind resistance. I think about 50 lbs of water in the water heater and think... meh.
I check the anode rod necessarily every time I sanitize, which is about once a year. I might do twice a year depending on how long the Pod has been sitting idle.
I figure it'll last this season and then need to be replaced. When I sanitized this spring, half of it was down to the central steel rod but the other half still had considerable magnesium remaining. |
Alan
Thank you very much for your replies. You are really , a bunch of great Podders.
Leonard🌵
I will join the chorus and keep is short and simple. No, I do not drain for the reasons the above posters gave.
Page <1234> |
