  New Posts New Posts RSS Feed: Jensen radio
Topic ClosedJensen radio
itspossible2 View Drop Down
Direct Link To This Post Topic: Jensen radio
    Posted: 30 May 2018 at 4:34pm
I have a 2015 178 and whether plugged into 120 volts or on battery something weird happens. I'll walk by the unit in the driveway and the radio is on, even though it was turned off. I've been working on her unit outside and all of a sudden the radio turns on again, for no reason. I was thinking of adding a switch to the power line just to stop accidental battery drain, has anyone else had this issue?
thanks
Direct Link To This Post Posted: 30 May 2018 at 5:12pm
Check the ALARM function and make sure it is OFF.
Direct Link To This Post Posted: 31 May 2018 at 9:45am
thank you, I think it was the alarm.
TheBum View Drop Down
Direct Link To This Post Posted: 31 May 2018 at 10:28am
Ah, and here I was suspecting it was gremlins. :)
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
lgblau View Drop Down
Direct Link To This Post Posted: 31 May 2018 at 12:49pm
I had the Jensen in my last motorhome, and it would come on in the middle of the night ( usaually at an  rv park).Finally had to disconnect the outside, entertainment center, speakers.
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 31 May 2018 at 3:07pm
Tat was Gremlins. I've had those too.
Direct Link To This Post Posted: 31 May 2018 at 3:39pm
LOL I was thinking of ghosts or your someone messing with you!
Direct Link To This Post Posted: 03 Jun 2018 at 6:55pm
Problem solved, I spliced a switch into the power wire to the radio and use it to disconnect power rather than using the power button on the unit. This also puts an end to power drain from the battery when the radio is off but drawing power for the clock.
