12 Volt light plug |
Post Reply | Page 12> |
Jackdaddy
Newbie Joined: 10 Oct 2013 Location: San Gabriel, CA Online Status: Offline Posts: 9 |
Topic: 12 Volt light plug Posted: 03 Jul 2018 at 10:12am |
I have a 2014 182G and I plugged a small inverter into the 12 Volt lighter plug that is on the same wall as the TV and all was good until I plugged a Cordless Electric Kettle, 1-3/4 Qt, 8-7/8Hand now the 12 Volt plug does not work. I checked all the fuses and they all look good. Does anyone know if this plug has it's own fuse, maybe on the back of it?
TheBum
Posted: 03 Jul 2018 at 11:25am |
Check the fuses again with a multimeter. That kettle is rated at 1500W, which is 125A @ 12V. I would be really surprised if the fuse didn't blow. The only way that's going to work is to wire a socket directly to the battery, and then the battery isn't going to last very long.
Alan
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2631 |
Posted: 03 Jul 2018 at 11:33am |
Hoo boy. Yeah. Even if you had a big enough fuse, and big enough wire. Your battery(ies) won't last long with that kind of load.
Pete Brayton
Senior Member Joined: 29 Jul 2015 Location: Parker, CO Online Status: Offline Posts: 124 |
Posted: 03 Jul 2018 at 11:37am |
There might be a fuse in the 12 volt plug of your inverter that may have blown.
2021 Rpod 196
2013 Ford 150 V8 |
TheBum
Posted: 03 Jul 2018 at 11:56am |
I thought about that after I replied. BTW, you'd also need at least a 1500W inverter. |
Alan
Jackdaddy
Posted: 03 Jul 2018 at 12:18pm |
Thanks everyone. I am going to check the fuses with a multimeter and go from there. I just ordered the BESTEK 200W Power Inverter that I want to plug into this 12 volt plug so I can charge my cell phone and use the TV when we don't have hook-ups.
Posted: 03 Jul 2018 at 12:20pm |
Not to mention you'd need something like 2 AWG wire feeding that inverter.
Jackdaddy
Posted: 03 Jul 2018 at 12:28pm |
I may install this new 200W inverter this way. https://www.youtube.com/watch?v=0259zbyOOsY
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 03 Jul 2018 at 12:53pm |
Why not just use a tea kettle on the stove?
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 03 Jul 2018 at 1:05pm |
You don't need an inverter to charge cellphone - I installed one of these and it works great:
