  New Posts New Posts RSS Feed: 12 Volt light plug
Topic Closed12 Volt light plug
Jackdaddy View Drop Down
Direct Link To This Post Topic: 12 Volt light plug
    Posted: 03 Jul 2018 at 10:12am
I have a 2014 182G and I plugged a small inverter into the 12 Volt lighter plug that is on the same wall as the TV and all was good until I plugged a
Cordless Electric Kettle, 1-3/4 Qt, 8-7/8H
and now the 12 Volt plug does not work.  I checked all the fuses and they all look good.  Does anyone know if this plug has it's own fuse, maybe on the back of it?
TheBum View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 11:25am
Check the fuses again with a multimeter. That kettle is rated at 1500W, which is 125A @ 12V. I would be really surprised if the fuse didn't blow. The only way that's going to work is to wire a socket directly to the battery, and then the battery isn't going to last very long.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 03 Jul 2018 at 11:33am
Hoo boy. Yeah. Even if you had a big enough fuse, and big enough wire. Your battery(ies) won't last long with that kind of load.
Pete Brayton View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 11:37am
There might be a fuse in the 12 volt plug of your inverter that may have blown.
2021 Rpod 196
2013 Ford 150 V8
Direct Link To This Post Posted: 03 Jul 2018 at 11:56am
I thought about that after I replied. BTW, you'd also need at least a 1500W inverter.
Alan
Three cats
Direct Link To This Post Posted: 03 Jul 2018 at 12:18pm
Thanks everyone.  I am going to check the fuses with a multimeter and go from there.  I just ordered the BESTEK 200W Power Inverter that I want to plug into this 12 volt plug so I can charge my cell phone and use the TV when we don't have hook-ups.
Direct Link To This Post Posted: 03 Jul 2018 at 12:20pm
Not to mention you'd need something like 2 AWG wire feeding that inverter.
Direct Link To This Post Posted: 03 Jul 2018 at 12:28pm
I may install this new 200W inverter this way.
https://www.youtube.com/watch?v=0259zbyOOsY
voisj View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 12:53pm
Why not just use a tea kettle on the stove?
SLOPODMODS
John&Sue,SLO,CA
Ben Herman View Drop Down
Direct Link To This Post Posted: 03 Jul 2018 at 1:05pm
