Confused at Battery Shut Off Switch |
Post Reply | Page 12> |
clickscrazy
Senior Member Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
Topic: Confused at Battery Shut Off Switch Posted: 15 Jul 2018 at 8:08am |
I went to install my battery shut off switch after looking at a few pictures and became a bit confused.
On my positive, I have 3 red cables hooked to the positive terminal. Should I put all 3 of those positives to my switch, or should there be some that stay there. I also got a 4 Gauge wire...and I think that is way to big. Just FYI. Not flexible, too big for the terminal.
2018 R-Pod 171
2014 VW Touareg TDI |
Senior Member Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1447 |
Posted: 15 Jul 2018 at 8:25am |
Put the switch on the negative side. It's safer and does the same thing. There is a lot of toMayto / toMAHto about which side to put the switch on. Google it if you want to. TT
FJ Cruiser |
Posted: 15 Jul 2018 at 8:39am |
+1 - Switch on negative side.
Posted: 15 Jul 2018 at 8:42am |
The rule I learned was connect the positive first, negative last. Disconnect negative first, positive last.That is why I put the disconnect on the negative side. It has worked fine that way. For your jumper, 4 Gauge is what I used but the terminals on it fit the posts just fine. I had previously purchased a 6 Gauge jumper but it ended up being just a bit too short to use with my cases so the one that I am now using is long enough to allow it to make the bends needed to fit around the lids. Now, as for the three wires on the positive, the heavy one is the main one to power the R-Pod. One of the smaller ones is likely the one for the solar input (mine was not connected when I bought it). If you have an electric jack, the third one is likely to power it.
clickscrazy
Posted: 15 Jul 2018 at 9:49am |
Easy solution. Put it on the negative side!
My 4 Guauge does fit, it is just doesn't hug the post as much as I would like. Maybe I will still use it.
2018 R-Pod 171
Posted: 15 Jul 2018 at 1:06pm |
Battery posts are different sizes. I forget which is bigger, but you may have a wire with a fitting for the other post. TT
FJ Cruiser |
clickscrazy
Posted: 16 Jul 2018 at 7:47am |
Hi All. I installed the cut off switch. I did what I think is a pretty seamless integration.
Mounted to the top of the box, the posts cleared. Black silicon around the switch to form a watertight seal (as long as that will last, probably 1 season). Screwed the switch on. Used a 19" 6 Gauge wire from Walmart. Glad I went a bit longer than the 12" one I started with. Question: Is it bad if I accidentally turn the battery off WHILE I am plugged into shore power?
2018 R-Pod 171
Posted: 16 Jul 2018 at 3:43pm |
If you do that, the converter won't be able to maintain your battery. The converter will supply 12V power to the 'Pod, but some have found having the battery connected provides a more consistent power. I remember reading one person who was running with the battery disconnected and found the furnace was not running right. Having the battery in evens out any power fluctuations.
clickscrazy
Posted: 16 Jul 2018 at 5:03pm |
Cool. Yeah, I plan on keeping the battery switch on, was just curious.
2018 R-Pod 171
ChuckH
Newbie Joined: 26 Jun 2018 Location: Houston, TX Online Status: Offline Posts: 3 |
Posted: 21 Jul 2018 at 11:41am |
Would someone post a picture or link where to buy a battery shut off switch? My wife and I just bought our R-pod last month and still learning a lot about it. Thanks for all your help.
