  New Posts New Posts RSS Feed: Amperage of Pod converter 45 or 55
Topic ClosedAmperage of Pod converter 45 or 55
Tibof View Drop Down
Direct Link To This Post Topic: Amperage of Pod converter 45 or 55
    Posted: 30 Jul 2018 at 1:21pm
Trying to help kids at a distance.  Seems the converter has gone out.  All fuses good, no 12 volt power unless hooked to the truck. None with land line either.  What amperage is the existing WFCO WF-8900 Series Power Center Converter Charger - 45 or 55.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
Richand Cindy View Drop Down
Direct Link To This Post Posted: 30 Jul 2018 at 3:07pm
Do not know the amps but we had the converter break on a trip and the battery would not charge and died. Went to Sears and bought a battery charger and hooked it up (we were at a campsite with electric).  Trip saved.  We were good to go and had converter replaced under warranty when we got home
Direct Link To This Post Posted: 30 Jul 2018 at 3:34pm
Tibof,
Have you opened the front cover? There is a large spec decal on left hand side. I have a 2015 and it has a 8955 convertor - 55 Amps. Unless it has been changed in past the WFCO and most others have that spec decal. I read a post where a newer Pod had a 35Amp Convertor. That is best answer to your question.
Direct Link To This Post Posted: 30 Jul 2018 at 3:36pm
Direct Link To This Post Posted: 30 Jul 2018 at 3:38pm
  The WFCO we have in our 2017 RP179 is a 55 amp charger, but that's the DC (12V) side. On the AC (120V) side that translates to roughly 5.5 amps.
So it depends on whether you're talking about the AC side or he DC side.
You did not mention the model you are referring to, so if it's an older model R-pod, it might be 45 amps on the DC side.
TheBum View Drop Down
Direct Link To This Post Posted: 30 Jul 2018 at 3:41pm
As far as I know, all converters are rated by DC amps. AC amps are dependent on how efficient the voltage conversion is.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 30 Jul 2018 at 3:48pm
OMG - can't believe where these posts go, if you buy a WFCO it by model number is the rated amps, an 8955 is a 55A convertor, who cares about AC and DC amps. That is all the PM is asking.
Direct Link To This Post Posted: 30 Jul 2018 at 4:12pm
Quoted for truth.. and want to add.. If the converter is toast, I recommend NOT replacing it with the WFCO replacement. Go with the Progressive Dynamics PD4655.. only a couple dollars more and a hella better reputation.
Direct Link To This Post Posted: 30 Jul 2018 at 5:08pm
Sorry. I took him literally. He asked amps, and all I was doing was asking which one.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 30 Jul 2018 at 6:42pm
No reason to get ugly.  The OP asked a question that others tried to help with.  You don't make the rules here.  Let others talk.
2011 R-Pod 177
2010 Ford F-150
