  New Posts New Posts RSS Feed: Converter upgrade.
Topic ClosedConverter upgrade.
Awchief View Drop Down
Direct Link To This Post Topic: Converter upgrade.
    Posted: 22 Aug 2018 at 9:12am
Looking for anyone that has swapped out the WAFC 8735P that is coming in the current production Pods with a PD4135. Both PD and BestConverter say it is a direct replacement. I am seeing several noticeable differences.
Michael
mrm435075 View Drop Down
Direct Link To This Post Posted: 22 Aug 2018 at 11:13am
Look at the other 'Converter' thread in this forum.
Michael
2019 R-Pod 179 HRE Cocoon
2011 Tacoma TRD 4 door
Tibof View Drop Down
Direct Link To This Post Posted: 22 Aug 2018 at 2:16pm
Easy swap.  I just did it.  If you buy the separate Charge Wizard pendant, you don't even need to change the fuse board.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
Direct Link To This Post Posted: 22 Aug 2018 at 4:22pm
Tibof, thank you for your response, but guessing you  might of misread my post and didn’t use the 4135. It is a complete unit, not just an electronics board package. The entire assembly enclosure and all gets R&R’d in one piece.  The charge wizard is build into the 4135 does not even have a spot to plug in the pendent.
Michael
Direct Link To This Post Posted: 22 Aug 2018 at 4:31pm
what "noticeable differences" do you see? it's pretty straight forward, even if changing the whole thing.
Direct Link To This Post Posted: 24 Aug 2018 at 4:06pm
My bad; you are correct.  I swapped in a PD4655 assembly.  Its designed as a replacement for the WFCO. IMHO, it costs a bit more than the 4135 but has higher amperage and looks like and easier swap.
