  New Posts New Posts RSS Feed: Cable tv hookup
Topic ClosedCable tv hookup
Mbearden View Drop Down
Direct Link To This Post Topic: Cable tv hookup
    Posted: 28 Nov 2018 at 6:55pm
Twice we have stayed at campgrounds with Cable service.   It doesn’t seem to matter whether the Cable or Sat hookup we get nothing...
Mike Bearden
AL1010 View Drop Down
Direct Link To This Post Posted: 28 Nov 2018 at 8:23pm
We had that problem at Ocean Lakes. I just used my Apple TV . I’m curious to hear what said. I was told it had something to do with the antenna switch box.
Direct Link To This Post Posted: 28 Nov 2018 at 8:27pm
And the tv must have QAM tuner.
Direct Link To This Post Posted: 28 Nov 2018 at 8:35pm
I am stumped....very poor to nonexistent antenna reception...and the antenna booster is on.
Mike Bearden
TheBum View Drop Down
Direct Link To This Post Posted: 29 Nov 2018 at 10:36am
You have to turn off the antenna booster to watch cable TV.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 29 Nov 2018 at 3:51pm
Tried everything except the switch.  Does it matter which input the coax is connected to?
Thanks for the help.
Mike Bearden
Direct Link To This Post Posted: 29 Nov 2018 at 5:27pm
Connect to the "cable"connection outside.
Turn OFF the antenna booster on the inside.
Turn on the TV, go into settings.
Select "cable" as your source.
Perform "channel search"
Enjoy.
Direct Link To This Post Posted: 29 Nov 2018 at 5:28pm
To watch OTA TV..
Turn on antenna booster.
Turn on TV
Go into settings, select antenna or OTA.
Perform channel search.
Enjoy.
Direct Link To This Post Posted: 29 Nov 2018 at 5:32pm
+1 - Yep
Direct Link To This Post Posted: 29 Nov 2018 at 6:42pm
Please Note:  Spectrum converted all of Ocean Lakes’ campsite cable to all digital on March 5, 2018. Our team has worked hard to assist Spectrum’s staff and our guests in this mandatory conversion. It has been a process and we apologize for the inconvenience and frustration it may cause. We continue to work with Spectrum on all issues.
Some Issues We Know About:
• Spectrum advised us that most TVs work. Tube televisions and flatscreen TVs manufactured prior to 2010 do not work.
• The Seiki brand TV rarely works with digital cable (QAM issue).
• Your camper TV must have a QAM tuner.
• The majority of Westinghouse TVs cannot be programmed.
• The splitter inside the camper may not be heavy duty enough and may need to be replaced. Ocean Lakes RV Center has found this rare issue.
