  New Posts New Posts RSS Feed: Brake wiring shorted and smoked.
Topic ClosedBrake wiring shorted and smoked.
Direct Link To This Post Topic: Brake wiring shorted and smoked.
    Posted: 04 Dec 2018 at 9:19am
Originally posted by davidi
Thank you furpod!
Very much appreciated! So the brake controller pin must output different voltages from the brake controller... learn something new every day.
Your brake controller outputs a variable voltage base on how hard you are braking.. That's why it's called a "proportional controller" and the voltage is provided by the controller and TV.
There are "timed controllers" also, hopefully no one sold you one of those...
The breakaway is powered by the Pod's battery, and that's why it's unsafe, (and against the law in many/most places) to tow without a battery in place. It has no proportion or controller, it just, when that pin is pulled by the separation of the TV and trailer, sends everything it can to the brakes, so hopefully, it doesn't crash into anyone/thing.
davidi View Drop Down
Direct Link To This Post Posted: 04 Dec 2018 at 10:07am
This is what I came up with...
Direct Link To This Post Posted: 04 Dec 2018 at 10:44am
You are correct, probably will have a tougher time working from back of TV plug. You have the TV inside on your diagram.
Direct Link To This Post Posted: 04 Dec 2018 at 7:44pm
If you go under your pod, at the front, driver's side, you will see where the umbilical terminates and ties into the trailers wiring harness.
Direct Link To This Post Posted: 04 Dec 2018 at 7:48pm
Smile Sure do have the wrong pic...
I'll get under it and look for the terminations.
Thanks again
Direct Link To This Post Posted: 04 Dec 2018 at 7:51pm
It's OK.. as long as you get it sorted out. Also.. while those colors are "standard" they may or may not be what you find actually under your Pod..
