  New Posts New Posts RSS Feed: 2nd hitch receiver
Topic Closed2nd hitch receiver
Jakejep View Drop Down
Direct Link To This Post Topic: 2nd hitch receiver
    Posted: 23 Jan 2019 at 12:58pm
has any one ever added a second hitch receiver to the back end of their rpod? im looking to do this for my yakima bike rack. where would i get one that i can weld on?
JR View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 1:48pm
I use my Yakima bike carrier on the 1 1/4 receiver that comes on the R-Pod and move the spare tire.  The Yakima bike carrier will fit either a 2" or 1 1/4 receiver.  You don't want to put too much weight on that receiver, it's not too beefy.
Jay
179/2019
Shane View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 1:56pm
If I am not mistaken, I think the limit on the receiver that comes on the pod has a 500# weight limit.
michaeln View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 2:08pm
I would love to watch a video of someone hanging 500 lbs from that flimsy stock rear receiver.
Avery, CA
Direct Link To This Post Posted: 23 Jan 2019 at 2:13pm
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 6:47pm
500 pounds!!!  No, not by a long shot.  What Marwayne said.
Direct Link To This Post Posted: 23 Jan 2019 at 9:35pm
yeah thats what i am doing now eventually i was wanting to weld another one on but maybe not if theyre rated for such a low weight......
Motor7 View Drop Down
Direct Link To This Post Posted: 24 Jan 2019 at 6:49am
The frame rails on the pods are pretty lightweight steel. Then they are about 57" apart & the bumper that ties them together is even lighter weight steel than the frame. In order to significantly beef all that up to hang more weight off the back would require a lot of welding and engineering. The weight of that addition, plus the weight of the carry item would also take away from hitch weight which would have to be replaced.
I am actually surprised it's rated for 250. A couple of bikes or a small hitch hauler with a hundred pounds in it would all I would dare. On smooth pavement things would be fine, but some of our states and Canada have roads in really bad shape. The constant bouncing and banging can crack steel and break welds.
2016 R-Pod 176T
Pod People View Drop Down
Direct Link To This Post Posted: 24 Jan 2019 at 6:50am
I added a second 2" receiver so that I could use my bike rack. However, that was only part of the modification.  In order to successfully use the bike rack, more work needs to be done.  I also added a 2x2 frame to frame sideways cross member that supported the rear of the receiver and also added triangle gussets between the original receiver and the new receiver.  When we use the bike rack, we use a hitch tightner between the shank of the bike rack and the receiver to eliminate up/down and sideways motion inside the receiver.  We also use 2 cam straps. one on each side that goes from the top of the bike rack down to an eye bolt mounted at the end of the frame. here are some pictures
the idea is to eliminate all movement of the racks, the bikes and the shank. keep the shank as short as possible and the bikes as close to the pod as possible.
good luck
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 24 Jan 2019 at 6:52am
I should have added that I got the 2" receiver at Harbor Freight for about $12
Vann
