  New Posts New Posts RSS Feed: Water Heater on Propane
Topic ClosedWater Heater on Propane
Direct Link To This Post Topic: Water Heater on Propane
    Posted: 06 Apr 2019 at 7:57am
And, if you want, for a $1.38 you can add a switch right by the water heater that is easy and convenient, at least on a 172, to use and not run the risk that someone else may not understand how the water heater switching works and ends up burning up the heating element.
Woody.1 View Drop Down
Direct Link To This Post Posted: 06 Apr 2019 at 8:57am
Thanks for all the replies.
+1 for DavMar on testing it all out before leaving the house.
podwerkz View Drop Down
Direct Link To This Post Posted: 06 Apr 2019 at 11:16am
Yep I just verified that on my r-pod, the water heater element is on circuit breaker 3 in the power center/ converter, and turning it off disables the water heater element (from inside the camper), but of course the 12v circuit and propane supply will still heat water if that red switch on the monitor panel is turned on.
Man, I wish EVERYTHING was this easy!
Tongue
