  New Posts New Posts RSS Feed: MAXxFan Upgrade Question
Topic ClosedMAXxFan Upgrade Question
CarlB View Drop Down
Direct Link To This Post Topic: MAXxFan Upgrade Question
    Posted: 14 May 2019 at 6:44am
Hello.  My 2018 179 has a MAXxFan, and I was wondering if anyone has upgraded to the MAXxFAN Plus?  The Plus has a thermostat, which is the feature I'm interested in.  I'd like to know if the "guts" of fans can just be swapped out without the need to remove and replace the portion on the roof.
Direct Link To This Post Posted: 16 May 2019 at 11:11am
I contacted MAXxFAN support, and they confirmed the housing is the same for both models, so I'll report back on how easy the swap-out was.
Tnpoder View Drop Down
Direct Link To This Post Posted: 12 Apr 2020 at 1:02pm
Curious as to how the swap went..... thinking of doing the same to my 190.
2018 190
2019 Tacoma Sport 4x4
mjlrpod View Drop Down
Direct Link To This Post Posted: 13 Apr 2020 at 7:22am
I assume you want a thermostat so the fan kicks on when it gets to hot inside? When it's not at a campsite. I don't know if your afraid of killing the battery, but I pretty much turn my fan on low in the spring, and I shut it off in the late fall. At times I increase the speed when it's parked, and it's 100 degrees for a few days. I store mine at home, and keep it plugged into a 15 Amp plug, so the battery isn't a concern to me, and it's easy to go change speeds if I want.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
podwerkz View Drop Down
Direct Link To This Post Posted: 13 Apr 2020 at 10:50am
I kinda doubt that asking questions of the OP will get a reply. Only 4 posts in a year.
