  New Posts New Posts RSS Feed: FRIDGE ON PROPANE
Topic ClosedFRIDGE ON PROPANE
hogone View Drop Down
Direct Link To This Post Topic: FRIDGE ON PROPANE
    Posted: 01 Jul 2019 at 5:19am
I attempted to clean burner area and used some compressed air to no avail.  Attempts to light, may stay lit for a couple seconds but goes out.  Thoughts, hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 01 Jul 2019 at 5:47am
If its clean and makes a good blue flame initially but then goes out it after a few seconds it could be the flame detection signal, which is there to sense whether the flame is lit or not and shut off the gas if not. I think the signal is produced by a thermocouple. You can disconnect the thermocouple and check it with a multimeter on the millivolts setting. I think is should be producing about 25 millivolts but I could be mis-remembering.
Kup-Pod View Drop Down
In my old tent trailer I used to get tiny spider webs in the burner orifices that were quite sticky.  Compressed air may have blew through them but not cleaned the, out completely.  Maybe the gas is getting through but not at a sustainable volume.  It would be worthwhile to clean the burners orifices with a wire.
2017 RP-178
2021 F150 5.0l
"Lead me on a level path"
Direct Link To This Post Posted: 01 Jul 2019 at 7:45am
Not knowing just where and how you used the compressed air, make sure the chimney is clean. Run a rag up and down it, etc. I was surprised how little of a amount it takes to disturb the flow and keep the thing from running right.
podwerkz View Drop Down
Direct Link To This Post Posted: 01 Jul 2019 at 1:12pm
Is the furnace and the stove working?
Direct Link To This Post Posted: 01 Jul 2019 at 5:26pm
podwertz:   yup, they work strong!!!!  and gas water heater.  out to tear it up again as we speak!!  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 01 Jul 2019 at 7:32pm
burning stronger than ever!  hogone
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Direct Link To This Post Posted: 01 Jul 2019 at 8:58pm
No wire please! Use denatured or isopropyl alcohol. Poking  a wire through there could damage the orifice.
Direct Link To This Post Posted: 02 Jul 2019 at 5:52pm
Fair enough on the wire comment, thanks Stephen.
Glad to hear you got it cleared up Jon
2017 RP-178
2021 F150 5.0l
