air and heat on same time |
jeffreypenhall
Newbie Joined: 19 Nov 2014 Location: Pacific Northwe Online Status: Offline Posts: 18 |
Topic: air and heat on same time Posted: 12 May 2015 at 7:14pm |
I have a 179 new and ran the air conditioner for a short time, mostly as a test. I raised the thermostat so the heat would kick on and the heater / blower started but the air conditioner continued to run. With both running it was loud. Of course this only happened while I was plugged into AC. I turned everything off, disconected AC and turned on the heat. Worked fine. Any idea why air conditioner AND heater would run at the same time?
R-POD is R-PAD
Black Ford F350 Oregon License "HQRSE" |
CFWARREN
Senior Member Joined: 12 Apr 2015 Location: Spokane, Wa Online Status: Offline Posts: 148 |
Posted: 12 May 2015 at 7:35pm |
I had the same but opposite situation, when I tried to run the heat, the AC would come on also. I believe the answer is that on the thermostat, you need to make sure the fan setting is set to "auto", then you should be fine. At least that's what I was told, try it and let us here know if that's the right answer!
2016 179 - Hood River Edition
2008 Nissan Xterra |
Posted: 12 May 2015 at 10:12pm |
That is the correct answer. Fan control to auto.
yalilminx
Newbie Joined: 13 Apr 2015 Location: ohio Online Status: Offline Posts: 14 |
Posted: 23 May 2015 at 8:34am |
Lol. I just spent the whole night running both the ac and heat because of this. ... put fan to auto and worked like a charm! I should have looked at this last night. That fan is loud!!! Thanks!
2015 rpod 176t
Jarhead
Newbie Joined: 03 Oct 2019 Online Status: Offline Posts: 12 |
Posted: 03 Oct 2019 at 11:42am |
Would be nice if the owners manual actually explained a few things about the unit
Posted: 03 Oct 2019 at 2:43pm |
I think it is designed to help circulate the heat through the cabin. I have ours set to "Auto" so the AC fan won't run and then I put a small fan at the opening under the bed where the heater is (RP179) to circulate the heat and air. It is a lot quieter. I am currently using an O2 Cool Fan that can run on batteries. It came with an AC adapter for the 9V power for which it is designed. However, it will run on 12V if you have a suitable adapter. It will just run a little faster and be a bit louder. In any case, it is still very much quieter than the AC fan.
Posted: 03 Oct 2019 at 3:44pm |
Owners manual, I built mine, I didn't get one.:)
karllindgren
Newbie Joined: 04 Feb 2017 Online Status: Offline Posts: 3 |
Posted: 29 May 2021 at 4:18pm |
Happened to me, you might half to reset thermostat,
Dometic Duo-Therm Thermostat Reset and TroubleshootingMar 03, 2021 ยท 1. Turn the switch off. 2. Now at the same time press both the mode and the zone buttons while turning the switch back to On. 3. As you are doing that the letters FF should appear in the digital display and will remain there until you release... 4. Hold the zone and mode buttons until these letters |
