  New Posts New Posts RSS Feed: Loading and balancing the trailer
Topic ClosedLoading and balancing the trailer
Direct Link To This Post Topic: Loading and balancing the trailer
    Posted: 17 Oct 2019 at 9:40am
Originally posted by jato
If I were to add 100 lbs behind the axle would it be the same, regardless if it is 12" behind or 48" behind, or is there another formula for this as well?
No. With a longer moment, the effect on the CG increases. So adding 100 lbs 48" aft will have a much greater effect than 12" behind.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 17 Oct 2019 at 10:05am
I get that part pretty well now. I believe Jato is referring to weight on the axle as making no difference. As he said, loaded behind the axle.
To that, I believe him correct. Makes no difference (that I can see) where it's placed (behind the axle) as far as just weight to axle.
If I'm wrong in this please correct. I want this spreadsheet right.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 17 Oct 2019 at 10:43am
If I understand the question, I think that is incorrect.  Remember that in a statics problem both the weights and the moments have to independently net out to zero.
So say if you add 100 lbs 4 feet behind the axle and the axle to hitch distance is 13 ft then you have reduced the hitch weight by 100*4/13=31 lbs. So to net out the new trailer total weight the axle weight has to go up by 100+31=131 lbs.
If instead you add the 100 lbs 4 ft in front of the axle then the hitch weight is increased by the 31 lbs so the axle weight only goes up 100-31=69 lbs.
Make sense?
Direct Link To This Post Posted: 17 Oct 2019 at 11:10am
Make sense?
Scary, but yes it does!
I just saw that in the spreadsheet for the hitch and forgot to add the weight to the axle. As I understand, the battery of 136#'s netted out 107#'s to the hitch, so adding 29#'s to the axle.
Probably best to ask by showing to hopefully explain better.
* The first part is the Battery Distance x Battery weight / distance of hitch to axle. Resulting in 107#'s to the hitch and 29#'s to the axle.
* Second part is the new hitch weight x distance to axle / distance to load. Resulting in 253#'s to counter balance the 107#'s.
The second part is my worried about part..
Shame the cell colors don't come through..
Batteries
Battery box to Axe X
weight. W
Distance to load. L
123
136
66
Weight at hitch (WH)       X x W / DHA
Distance hitch/axle DHA
WH x DHA / L
107
156
Counter balance weight
253
W - WH
Weight back to axle
29
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 17 Oct 2019 at 2:36pm
Re-loading and weighing is taking time.. Thankfully it's raining and I can do this.
I've now past the axle and working aft. In the 182g I have a upper bunk which I remove and add a rear corner cabinet.
This has brought on a interesting situation and as I think of it it applies to some of the fore weight as well. That is factoring weight per side on the axle.
Being the slide side is probably heavy from just that, then add frig goodies and my pantry (your Micro) this seems to be fairly important. Especially since my issue was the frame on slide side.
Why do I have this feeling OG has a formula for just that.. I do not mean to put you on the spot, yet you do really understand these things. So I guess I do.. and it is so appreciated.
So far the numbers are coming out heavier than I weighed in at, yet not quite done and seem to be on track.
Goal for me is to get to my factored hitch weight 400#'s (or up to 420#'s). With all said and done right now, I'm looking at 281#'s of gear in the garage (or storage under). Which I highly doubt I now carry. I may just throw the spare back in the trailer and open up some cargo area in the Tacoma.
Onward I go!
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 17 Oct 2019 at 3:33pm
I think your 107 lbs and 253 lbs are correct if I understand your spreadsheet right. But you need to also consider the effect of the 253 lbs on the axle (and on the frame aft of the axle). I think if you add the 253 lbs 66 inches behind the axle you are increasing your axle load by 360 lbs (253 lbs plus the reduction in hitch load of 107 lbs). That's a LOT of extra weight/stress on the axle/stress on the frame to carry around.
What is your Taco's hitch weight limit? Do you really need to keep the hitch weight down to 420 lbs?
I don't have a handle on the side to side weight distribution on the axle. I do agree that the slide side is almost certainly heavier, numerous ppl have noticed that that side rides lower on their pods, and its my impression that there have been more axle failures on that side. The thing that is needed is for someone to actually measure their side to side weight balance. That's not so easy. It could be done with individual wheel scales or (maybe) with a Sherline with a board on top using legos to get each trailer wheel on there one at a time.
Direct Link To This Post Posted: 17 Oct 2019 at 8:19pm
Wow, this is very interesting and you are taking it to a level that I am going to need more time to digest.  In the meantime I have a tee time for golf at 10 am, while my wife is waiting to go camping and then we will camp this Friday thru Sunday morning in Kingsley (MI).  Come home for a day and then leave again Monday morning for our last r-pod gathering with other podders near Roscommon at S. Higgens Lake State Park for a few days.  NO SNOW FORECAST ! so that is a good thing.  Problem is that for the 30 days we were gone in September in CO and UT we had bountiful sunshine EVERY day, man did we get spoiled!  Then back to gloomy northern Michigan.  We are about ready to go back west again, as you can imagine if you live in this neck of the woods.
Back to the topic at hand,  Keep the posts rolling, I am learning a lot here, thank you all for all your expertise, hopefully this brain will be able to retain more than a trace of what has been shared thus far.
Direct Link To This Post Posted: 18 Oct 2019 at 5:52am
I'll trade you your next snowfall for my next tropical storm if you want.  LOL
Here's a thought experiment that hopefully will make it easier to understand what's going on with trailer weight and balance.
A 200 lb dad makes his 100 lb kid a teeter totter. For the sake of making the numbers easy let's say the teeter is a 16 foot board and assume its weight is negligible.
Now, the kid sits on the left end of the teeter and lifts his feet. What happens? The rule is that both the forces and moments (torques) on the teeter have to end up netting out to zero for it to be stationary and stable.
So, the kid lifting his feet is applying a 100lb x 8ft = 800ft-lb torque due to gravity to the teeter. His weight forces it to swing counter clockwise till his feet touch the ground again. He will end up with 100 lbs of force pushing up on his feet to counteract the 100 lbs from gravity forcing it down. Net torque (moment) = 0 so nothing is rotating.
Total net force on the teeter also has to be zero or it will either lift in the air or dig itself into the ground. Since the teeter plus kid weigh 100 lbs and the ground is pushing up on his feet with 100 lb force to counteract the torque, the forces are balanced too, and so there is zero force required on the teeter pivot.
Now, let's say the dad gets on. Being a savvy guy on teeters, he sits 4 feet out from the pivot and lifts his feet. What happens?
He is now imposing a clockwise torque of 200 lbs x 4 ft = 800 ft-lb on the teeter due to gravity. This exactly balances the kids 800 ft-lb counterclockwise torque so the kid can lift his feet and the teeter doesn't rotate.
But what about the forces? There is now 300 lbs gravity force on the teeter from the weight of the two ppl on it, but neither one's feet are touching. So, were does the force get countered? By the pivot of course, which now has to push up with 300 lbs force. So the force on the pivot just went from zero to 300 lbs. even though we only added 200 lbs of weight.
This is whats going on with the rPod when you add weight aft (the dad) to try to reduce the hitch weight (the kid). The load on the pivot (the axle) goes up by the added weight plus the reduced weight on the hitch.
That's why its not such a great idea to add a lot of weight aft to reduce hitch weight. Its kinda self defeating at some point because it can quickly overload the axle.
It also increases the "polar moment of inertia" which is a measure of a vehicle's resistance to turning/sway. That's why the best handling sports cars are mid engine designs, by keeping most of the weight near the middle of the car its easier to get it to turn.  By having lots of weight out at the far ends its both harder to get a trailer to start swaying but more importantly its harder to get it to stop swaying once it starts.
So, I think the approaches to reduce hitch weight (in my order of preference) are
1) leave stuff at home
2) move stuff from the front of the trailer to in front of the tow vehicle rear axle (the most lightly loaded axle on the rig is the front axle of the TV).
3) move stuff from the front of the trailer nearer to but in front of the trailer axle.
4) move stuff from the front of the trailer to behind the trailer axle.
Direct Link To This Post Posted: 18 Oct 2019 at 8:34am
"But you need to also consider the effect of the 253 lbs on the axle (and on the frame aft of the axle). I think if you add the 253 lbs 66 inches behind the axle you are increasing your axle load by 360 lbs (253 lbs plus the reduction in hitch load of 107 lbs)."
Okay, I need to write this out to understand..
Will deleted the long write up and here's the short version:
Being hard for me to understand how the 107lbs come back into play again, I used the math you have shown me. Load (253lbs) x distance to axle (66") / Distance to hitch (156"). That solves at 107lbs.
What I have just learned is that by counter-balancing I'm placing the full weight of the object on the axle. Guess I should have realized that, yet hoped it would not.
"What is your Taco's hitch weight limit? Do you really need to keep the hitch weight down to 420 lbs?"
650lbs. This exercise is to show me what and where. I do believe I carry approximately 200+lbs aft of axle. I will discover how much and where I actually carry. At 400-420lbs I have no requirement for WDH. So ya, I'd like to keep it in that range. Will it end up there? Only completing this exercise and knowing what I have can I make that decesion.
Byways no Highways
2017 Tacoma
Truck Camper Build
Direct Link To This Post Posted: 18 Oct 2019 at 2:28pm
Getting very close and being able to really look at things now. I have almost everything back, short of a few lighter items which I will do and add. What I hope is you take a look and offer suggestions of improvement.
First up is my results of of now.
Next is a sample of fore axle item
Then a aft axle item
Still need to work coloring of cells.. Yellow being input cells, light blue as informative and green as important results.
I found that if I inputed 'aft' of axle as a negative, the formula's worked. Yet still required inverting to positive in one of the result cells. I'll work on that formula so that's not required.. Actually didn't think of how till I wrote this.. Ya, for me I have to write things out to 'see' what I need to do.
Anywho. You can see where I'm at and got there fairly quick. Results section is the most important to me! 400lbs of items, placed accordingly and I have 619lbs on the axle. WOW! I going to hookup tomorrow and run to the dump and hit the scales. Really need at this point to factor a correct baseline. Right now I have my baseline at 2800lbs (remember, I was stripped further tan what factory calls empty).
More to come!
Byways no Highways
2017 Tacoma
Truck Camper Build
